Troy Patterson wrote:Mediocre cam, wrong manifold type and small carburetor.Parkhurst wrote:This engine performed very well in testing, peaking at 545hp (6,400) and 500 ft-lbs. (4,900).
It's not "peaky" either. At 3,500 its making 415 ft-lbs and 280 hp. The average power numbers are really good all throughout the rpm range.
CR is 9.5:1 and cam is a Comp XR286 (12-772-8) solid roller. Heads are AFR CNC 215s, manifold is RPM Air Gap. Demon 825 carb, MSD ign.
Scott Parkhurst
Editor
Street Thunder Magazine
Troy Patterson TMPCarbs.net TMP Carbs
I believe those are "magazine build" commandments # 2, 3, 5, & 1. #2, thou shalt not use mech. cams other than Comp XR series, #3 thou shalt not use ANY intakes other than rpm air-gaps, #5 thou shalt not use carbs that make excessive power, and #1 Most of all, thou shalt NOT, on penalty of excommunication, use a compression ratio that any sensible person would use when building a similar engine. #4 is Thou shalt not port , grind on or otherwise romance heads, or any part for that matter, just wash 'em and bolt em on.
