Distilled Water?
Distilled Water?
New BowTie block, radiator, hoses, & water pump. Is it worth the cost & effort to put distilled water in for coolant? I will be running some Redline water wetter.
Gus
215" Chassis Dynamics Dragster, 572 Bowtie
The benefit of distilled water is that it does not have dissolved minerals that will produce scale buildup. The disadvantage of distilled water is that it wants to dissolve everything.
The solution is to use a good coolant (anti-freeze) which will protect against corrosion and scale buildup. There is a very slight loss of heat transfer properties but is compensated by the higher boiling point. A higher pressure cap will also protect against boiling by raising system pressure.
Water wetter is crap and should not be used, in my opinion. It is only a surfactant and is not needed. It does not protect against boiling and leaves unwanted deposits.
Does your class of racing prohibit the use of glycol based coolants?
I use ionized water because our tap water here has way to much calcium in it and will adhere to the walls and create inproper heat transfer which in turn the motor will run hotter, i have no issues with ionized water.....cost me about $5 to fill the car and rad up so no big deal
[IMG]http://i44.photobucket.com/albums/f29/fishman1/S7300198-1.jpg[/IMG]
Bad Water
DO NOT USE DISTILLED WATER IN A VIRGIN BLOCK!!!!
If you use distilled water in a virgin block (not had anti-freeze in it) the water will try and remove minerals from the metal and "eat" any aluminum it comes in contact with.
In my case we put distilled water and "Ice" in a brand new A-460 block with aluminum SCJ heads. No anti-freeze and sure enough, bad things started to happen. The cooling system "pressurized" all by itself, sitting in the trailer. Built up so much pressure it would push hoses off radiator and intake!
We were using Royal Purple "Ice" so I called Royal Purple. Tech told me exactly what to do to fix my problem. We flushed and refilled the entire cooling system with "filtered" water and anti-freeze. Ran the motor until we were sure the cooling system was now coated with the anti-freeze (which would nuteralize the effects of distilled water on surfaces). Then we removed the anti-freeze and put plain filtered water only into the cooling system and sure enough no more problems with the cooling system.
If you use anti-freeze you can use distilled water but don't use distilled water by itself or with Ice or Wetter, you won't be happy with the results.
Bruce
Bruce
Any day dragracing is a GOOD day!
Anti-freeze
If you drag race and dump anti-freeze on the track you are going to make lots of new friends!Tod74 wrote:why do people not just want to run 50 -50 water and anti freeze? what is the advantages / disadvantages of runing anti freeze verses water?
Best to use plain water; it will evaporate off the track and not leave any slippery spots.
- Rommel Racing
Dave,not trying to be a smart ass,but could you please explain how distilled water can be corrosive?David Redszus wrote: The disadvantage of distilled water is that it wants to dissolve everything.
On my last motor,I had been running distilled water and Redline Water wetter only(two bottles),and after 6 years running it this way,my block and heads looked as new as the day I first put it together.
I really thought that this was as good as it could get.
I was very happy with how clean the block was,no rust or staining at all.
Now, I might have to re-think my options for my new motor which is all aluminum.
Thanks,
Steve
-3400lb stock suspension 67 Camaro
-10.5-1 compression pump gas 540bbc.
-th-400, 4200 stall 9" convertor
-12 bolt 4.10's
-29.5x10.5 Hoosier radial slicks
- Best on motor only 9.59/142.24mph
-12 bolt 4.10's
- jmarkaudio
I live in canada and i buy ionized water at a place called canadian tire but i imagine you could buy it at some local grocery stores or a place that sells bottled water...costs $1.99 a galoonSideWinder wrote:Fishman
Where do you find ionized water?
Actually I mispoke. When I said not to use distilled water I meant not to use it just by itself. It works fine when used with a coolant. I use distilled water in all my cars with a coolant replenishment additive sold to the heavy duty trucking industry.If you use distilled water in a virgin block (not had anti-freeze in it) the water will try and remove minerals from the metal and "eat" any aluminum it comes in contact with.
Straight water is a problem since it has a low boiling point and can produce local steam pockets which then overpressurizes the system and results in an overflow coolant loss.
Some aftermarket coolant additives can be used but should only be used in a new, clean system.
Note that bottled water, or mineral water, is about the worst thing you can use. Much better to use water from a water softener.
