I have a set of 210 cnc ported heads from AFR. I was wanting to know if it is possible to get alot more out of them then what they come from AFR ? I mean bigger flow numbers. I'm been satusfied with them but freshing up the motor at the end of the year and just wanted to know.
Skip
AFR 210 sb chevy
- New Member
Re: AFR 210 sb chevy
Ask Larry (maxracesoftware). If I were considering it, he would be my first choice.Skip Honaker wrote:I have a set of 210 cnc ported heads from AFR. I was wanting to know if it is possible to get alot more out of them then what they come from AFR ? I mean bigger flow numbers. I'm been satusfied with them but freshing up the motor at the end of the year and just wanted to know.
Skip
Skip,Skip Honaker wrote:I have a set of 210 cnc ported heads from AFR. I was wanting to know if it is possible to get alot more out of them then what they come from AFR ? I mean bigger flow numbers. I'm been satusfied with them but freshing up the motor at the end of the year and just wanted to know.
Skip
For your circle track application there may be "something" in the heads
but as Shawn has pointed out, .. more information about your
entire combo would be needed to really make an assesment.
I rework CnC ported heads on a very regular basis and the AFR's can
be helped, ..
Curtis
Race Flow Development
