BBC Manifold Runner Parameters
I can't give you exact numbers but this is what I remember from fluids class and some tinkering. From a straight on shot the full circle is the most efficient shape for flow. But when the flow is coming at an angle (at entrance) it can be anything really. Mostly depends on the a variety of things. I have found that the correct shape is determined thru testing. I havent done any testing on a prostock intake but I am sure the reason the round is working for them is the distance from the carb to the intake runner is sufficient enough to allow it to react like a straight shot.
Todd
Todd
Yes I think Todd is right on, .. with the sheet metal maifolds
the plenum is big enough and the shape allows for a round opening, ..
in a single for cast manifold you don't have the room, .. so
tall entries is the way to get the proper cross sections.
Have a look at some current manifold, .. like a Dart or Brodix, ..
then perhaps some one can post a pick of a good ported one, ..
I don't have one in the shop righ now to post.
Curtis
Curtis
Race Flow Development
CBoggs,
On the photo you posted of a comp sheetmetal intake.. I noticed the bolts on the side and bottom of the plenum. Could someone shed a little light on what might be stuffed in there.
Great thread!
Schmidt,
Really nice cad work.. i think you've got a great idea, port spacing for the thousands of brodix and darts out in service right now would be a nice market.
Great thread!
Schmidt,
javier
it's discussed in the thread that contains that photo, ..jdeleon wrote:CBoggs,
viewtopic.php?t=1164
Varius forms of "stuffers" are used in the plenum to effect volume
and sometimes entry radius.
Curtis
Here are some guesses.
I have made a few sets of cutomer designed plates that are bolted into the inside of some older profiler manifolds that had short runners. It extended the runners and filled the plenum some. I also made some plenum spacers for the same guy.
I had a Honda Interceptor (back when they were cool (86?)) and it had these rubber tubes extending the carb into a v plenum. They were held down by a plate that had screws on the outside if I remember correctly.
I saw some manifolds at Honda HPD that had trumpets bolted to the inside.
Don't think that'll work, ..
here's photo from Larry's web site of a plenum, . Larry I hope
you don't mind.
See how the pairs of runners meet under each veturi of the carb, ..
perhaps try taking your original design and shift the runner where they
meet the plenum so they are side by side instead of on top of each other?
Curtis
you don't mind.
Curtis
I was thinking of how I would make this manifold if I wasn't building it from flat pieces.
or this one
What I see in the modified aftermaket manifolds are efforts to make longer runners by crowding them into the plenum. I am thinking that the existing manifolds are the way they are because of manufacturing costs and racers are just making the best they can out of what they have to work with. A casting like you see from Brodix can be made in green sand for about $100, one like my tunnel ram or the new one I just posted would cost about $300 to cast in dry sand. I know for certain the way the runners are angled on all single plane manifolds that I have seen is so that the cope side of the pattern can mold the entire top side of the manifold.
Even if a manifold like the one I just posted made 50hp, I doubt that brodix or Dart etc. would make it becuase it would cost 2-3X what the current manifolds cost to tool and cast and as far as I know, none of them even use 3D solids CAD to design thier manifolds or tooling and making a manifold like this would be a nightmare without CAD CAM.
or this one
I am not convinced that those dividers guide fuel distribution for a couple of reasons:See how the pairs of runners meet under each veturi of the carb, ..
1. When you look straight down on them they are off center from the venturis and appear that they would bias flow toward one cylinder much more than the other.
2. The firing order influence is similar on cylinders 1&2 and 7&8 yet the manifolds seem to be indifferent to this characteristic. My conclusion is that there really isn't that much science there.
On friday I was at a foundry that makes prototype cast manifolds for small block engines (probably NASCAR) directly for OEM (about 15K each). On those manifolds the plenums were long and narrow. The end runners were about 3 inches to the (front and back) away from the carb. Since they were making at least 8 of them that I saw, I guess this design has some merit (at a $115,000 bill).
The old "inside" looked good, the outside runners were point straight at the plenum.
On the new "inside" it looks like you moved the inside runner out (front & rear) and moved the
outside runners move so. Can you move both sets of runners "in" (front to rear) so the outside set
have a straighter show from the plenum. I think you tried to make it too much like a tunnel ram,
and it should still be like a singleplane - tall, with a straighter shot from the plenum to the outside
runners, with as large a radius at the runner dividers as possible.
67 camaro
girly rollers on pumpgas:
420 - 641hp BretBauerCam, 1.39, 9.79 @ 137.5
383 - 490hp 224/224, 1.56, 10.77 @ 124.6
502 - 626hp 252/263, 049s 1.44, 10.08 @ 132.7
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
62 Nova cruiser
224/224 HR cam
1.57 10.97 @ 121.2
I have access to Fluent CFD, COSMOS and the legacy stuff from SDRC.
I doubt that any of those basic software will show reveal any suprises unless you get into modeling the pulses with something like riccardo and I have heard the Fluent has something for that now too. Unfortunatly ricardo is way beyond what an aftermarket or hobby person can afford in money or the time to learn it, plus I don't have the pressure/timing data to input. Those type of analysis projects must have teams of people collecting data.
I would like to work with someone that did IC stuff to aleast get their perspective.
One of my coworkers used to work at a company that did analysis software that included CFD. He told me that when you get to IC stuff that success is considered coming within 25% of what you find in the real world.
I tried to model a surfing wave one time in CFD, I think I was at 150 hours before it looked anything like a real wave.
