Question about a Nascar Valve train setup.
VW Racer
Post by VW Racer »
Hi I was wondering if someone in the know can clear something up for me. I was reading some info ( on the net )and was wondering if there is any truth to this because it doesn't sound right to me.
First, Do nascar engines run Beehive springs?
Second, are the cams and spring rates set up as such that the lifter actually "lofts" or launches itself off the cam lobe to achive a higher at valve lift?
Thanks.
Leon Sterett
Post by Leon Sterett »
No to all the above.
Leon
OldSStroker
Post by OldSStroker »
Leon Sterett wrote:No to all the above.
Leon
No (intentional) loft?
The last thing I heard, there was some of this being used. Cam velocity (lift/degree) is physically limited by the lifter diameter of course, so controlled loft can be useful.
No offense, but where did you get your info, Leon?
let r eat
Post by let r eat »
They've been doing this in Briggs and Stratton engines for years.
SchmidtMotorWorks
Post by SchmidtMotorWorks »
I haven't see it but heard from a reliable source that some NASCAR engines do not have adjusters on the rocker arms. I guess they adjust the level of the arms or change pushrods.
joe
Post by joe »
at one time they got a ballistic effect from pushrods that weren't sufficiently stiff too properly translate all the cam motion to the rocker . The pushrods would bend as the lifter raised then when the lifter reached its plateau the pushrods would straighten themselves and loft the valve a small amount.
From what I've heard they found this out after the fact . They put stiffer pushrods in and dropped some hp so they made the cam more aggresive to compensate.
jacksoni
Post by jacksoni »
joe wrote:at one time they got a ballistic effect from pushrods that weren't sufficiently stiff too properly translate all the cam motion to the rocker . The pushrods would bend as the lifter raised then when the lifter reached its plateau the pushrods would straighten themselves and loft the valve a small amount.
Is my understanding that bending pushrods break sooner rather than later, that lofting valves is bad for longevity of all the valve train and I think Brad Morgan (Darins brother) says on their CD that they picked up power when they put stiffer pushrods in and got better valve control. Might work for a Briggs but not so sure of a 9-10k rpm nascar or prostock motor.
Robert Kane
Post by Robert Kane »
I would think that lofting the valves is an unavoidable occurance in any high end pushrod engine, with the aggressive cam lobes and high rocker ratios. I would assume that engine builders / cam makers work some amount of "controlled" lofting into their combinations, and it would seem valve bounce is a much bigger problem from a power standpoint. I do think a Cup engine would need to control lofting much closer to be able to stay together for 500+ miles than a Prostocker does.
OldSStroker
Robert Kane wrote: Lofting the valves is an unavoidable occurance in any high end pushrod engine, with the aggressive cam lobes and high rocker ratios. Engine builders / cam makers work some amount of "controlled" lofting into their combinations. Valve bounce is a much bigger problem from a power standpoint. A Cup engine would need to control lofting much closer to be able to stay together for 500+ miles than a Prostocker does.
Sorry for the edit of your quote, Robert, but the way it reads here ^^sounds like you know whereof you speak. Are you just being modest? I have heard almost those exact words from folks very close to the situation. Methinks you might be one of 'em.
Shaun
Post by Shaun »
I've heard .750 lift, .040 - 0.60 loft. 175 seat, 500 open . After lofting, the valve supposedly lands with about 1200 lbs of pressure.
Ron C.
Post by Ron C. »
From what I hear it alines with Kane's comments. Pro Stock cams can get away with a little bit of controlled drop where a 500 mile motor would never make it to the finish line.
Creekside Racing Ministry
John 14:6
Ron Clevenger
CSU Gas Dominator ProCharger nonintercooled
Top Eliminator West http://www.topeliminatorwest.net
Steve Morris http://www.stevemorrisengines.com
6.49@219mph (still tunning)
Racer7088
Post by Racer7088 »
They all have some loft going on and yes at some tracks they use beehives as well. The Beehives have been on the lower rpm plate engines when they have shown up and they have loft too. Cup shops have spintrons and they use them a lot.
Erik Koenig
Houston, TX
http://samracing.com
http://HKRacingEngines.com
CNC BLOCKS
Post by CNC BLOCKS »
My partner that had worked with me for 12 years now works for one of the top Cup teams in there engine shop and is also the engine tuner and the last Cup race I went too while he was adjusting the valves he checked the seat pressure and they were 160 at the seat and low 400 over the nose the springs are 2000 dollars a set and there not the behive type and the rockers are adjustable and the plate engines run less pressures then that and there valve train componets are super lite the size of the valve stem are tiny compared to what most of us deal with. All ther cams are ground in house and haveing a spintron to test everthing on helps as well.
Website is up and running
http://hinksonautomotive-cncblocks.com/
Machine shop tour
http://hinksonautomotive-cncblocks.com/shop-tour/
Monthly Specials
http://hinksonautomotive-cncblocks.com/specials/
55MM babbit cam bearings with 1 hole
Robert Kane
Wish I was one of them! No, I am just a young man in my journeymanship who worked with a very talented but aged machinist, now looking to start my own engine business with my father. I try and learn as much as I can. This IS my passion- engine development, and I like to think if I had the funds in time I could be with those you speak of. This is a great place to exchange ideas and problems, so many talented minds. Also very encouraging to find my thoughts and quieries very close to those who have reached such levels of success. I just wish I could find more places to ask questions and pick some of the great minds.
Thank you for your kind words.
Robert.
