cloyes cam sprocket doesn't fit sbc block!
This is a cloyes set for the factory style chevy hydro roller cam. Part number is 9-3145. The problem is it collides big-time with the top oil passage that runs between the lifter gallery (this is a ZZ4 block). It definitely is designed for the retainer plate but compared to the factory gear it's a lot smaller dia.
What gives?
What gives?
It looks like it could be ground for clearance. It looks like it might have to get pretty close to the end of the oil gallery bore. (it has press in plugs)Keith Morganstein wrote:Can you grind the area of block? I do this on many SBC's with double roller, not just the factory roller cams.
The EPG factory roller sprockets usually require some clearancing too.
Kinda sucks since the block's all cleaned up, crank's in, etc. but that's not the first time I've been down that road
I'm kinda surprise because when it was ordered there was a note about the timing chain not clearing the stock timing cover, but no caution to "remove half the cylinder block"
What is "EPG"?
Those blocks do require a lot of grinding above the oil galley hole.
Website is up and running
http://hinksonautomotive-cncblocks.com/
Machine shop tour
http://hinksonautomotive-cncblocks.com/shop-tour/
Monthly Specials
http://hinksonautomotive-cncblocks.com/specials/
55MM babbit cam bearings with 1 hole
Machine shop tour
Monthly Specials
Cloyes lists a a timing set Part#s as follows
Hex-a-Just 9-3145A
***************Premium billet true roller 9-3645X9******
*** Original true roller 9-3145** the one you tried
Billet true roller 9-3545X9
Street true roller 9-1145
These are all listed for a 1985 and up with factory roller cam.
I think the 1 you choose is the same top gear as the older block
I use the billet set as I have seen the cast top gear loose teeth.
Hex-a-Just 9-3145A
Do any of these clear the casting?ProPower engines wrote:Cloyes lists a a timing set Part#s as follows
Hex-a-Just 9-3145A
The last two new GM blocks I've done had the same issue with the Cloyes double roller. I just taped off the block real good, ground away, and sprayed the front of the block down real good when done.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro 427" E85 powered small block, 9.95 @ 133 mph best motor ET through the mufflers. 1.319 best sixty foot.
- af2
Eric68 wrote:The last two new GM blocks I've done had the same issue with the Cloyes double roller. I just taped off the block real good, ground away, and sprayed the front of the block down real good when done.
Geese! The single works on all engines going more than 100,000 miles!
Why make extra work when you don't have to?
GURU is only a name.
Never failed one yet.rustang wrote:How do they stack up reliability-wise?Racerrick wrote:Get the single roller it should clear without grinding.
An old oval track engine I built many moons ago broke a piston at 7500rpm. Everything was destroyed as it blew to pieces and ventilated the block. The cam came out in 4 pieces! The single roller chain was still intact.
I'd say thats tough enough.
A double roller would have broken in half for sure.
