Roller cam bearings
Roller cam bearings
I have a factory production 1970 351 windsor block that I run. I run a solid roller cam, I switched cams a while back and also doing this I went with a set of 948-16 comp springs. the motor hasn't been run much maybe 5 1/8 mile passes and 5 1/4 mile passes. yesterday when I started the engine getting ready to load up I noticed a little ticking sound that got worse and worse. So i pulled the valve cover and had one really loose rocker I also noticed metal shavings under. I pulled the rocker and it had beat the end of the pushrod shut. It had spun the cam bearing. Is there any way to install roller cam bearings in this block. I have alot of money in this block it has the billet 4 bolt caps on it screw in freeze plugs, it also has been poured. Or is there any fix, is these springs to big for regular cam bearings, I never had this trouble before with the smaller springs.
On the Ford small blocks most of them go to a 55MM cam tunnel in the first 4 journals and rear is 50MM
Website is up and running
http://hinksonautomotive-cncblocks.com/
Machine shop tour
http://hinksonautomotive-cncblocks.com/shop-tour/
Monthly Specials
http://hinksonautomotive-cncblocks.com/specials/
55MM babbit cam bearings with 1 hole
Machine shop tour
Monthly Specials
cam bearings
If your plan on turning some rpm, and want accurate cam timing, i think it would be worth while to use the roller cam bearings. they not only reduce friction a certain percent, the allow slightley more oil everywhere else. and most importantly for performance. they locate the camshaft perfectly in the center of the housing bore for the most accurate cam timing. good luck!
Line boredlen-rob wrote:what needs to be done to install these in a production block?
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
