I have not attempted to make a rev-kit work myself, but as I recall, Wolf has said you can't really make a rev-kit fit on a BBC using a Dart Big M block along with lifters such as Isky's or Crowers. If anyone knows of a rev-kit that will work on this type setup, let's hear about it.CamKing wrote:Not if you go with a rev-kit.540 RAT wrote:Something else for us to consider in the pursuit of lifter longevity. We seem to be between a rock and a hard place on the lash issue...........
It'll make the clearance ramp do what it's supposed to do, and your lifters will live longer.
Of course, it may cause the rollers on your rocker arms to fail sooner.
Is solid roller lifter loading really the highest at idle?
Since it's the opening ramp that causes the pounding on the lifter, that's just pure genius at work.n2omike wrote: Comp's Xtreme Energy street cams are advertised to have lift ramps 'almost' as fast as their race cams, but slower closing ramps for less noise, and less pounding on the valvetrain and seats.
The slower closing ramp will help the seats, but won't have any effect on lifter life.
"inverted roller cam"new engine builder wrote:You guys seem to have forgotten more than I will ever know.
Can you please tell me what is an "inverted roller cam".
Was this a trademark name?
Or is this an actual technical term used to describe the cam??
"Inverse Radius Roller"
"I.R. Roller cam"
These are names to describe a roller cam profile that has an inverse radius(concave) on the opening and closing flanks of the profile.
Every Roller cam We've made since 1979 has been an Inverse Radius cam. Designing the profiles like we do allows us to get the area under the curve we want without having to increase the ramp speeds.
When comparing one of our IR cams to our competitors cam with the same area, our will have a much slower velocity at the seat.
Thats why I am on here.CamKing wrote:"inverted roller cam"new engine builder wrote:You guys seem to have forgotten more than I will ever know.
"I.R. Roller cam"
I have learned a lot the past few weeks.
Now if I could only retain all of it.
Thanks.
I have not attempted to make a rev-kit work myself, but as I recall, Wolf has said you can't really make a rev-kit fit on a BBC using a Dart Big M block along with lifters such as Isky's or Crowers. If anyone knows of a rev-kit that will work on this type setup, let's hear about it.[/quote]
I run a Crower rev kit with Isky EZX's and a Dart BigM,
it needs some fitting and machining, but it can be done.
Steve
Steve
Any chance of some pictures and/or some details as to the machining and fitting required. It would be nice to know what's in store before spending the money and tearing the motor down.ausbullet wrote: I run a Crower rev kit with Isky EZX's and a Dart BigM,
Steve
[quote="540 RAT
Any chance of some pictures and/or some details as to the machining and fitting required. It would be nice to know what's in store before spending the money and tearing the motor down.[/quote]
Crower kit 82001
Isky lifters 372-96-RH
Grind rev kit plates to fit 'around' head stud bosses on block,
Machine the spring holes in the plates deeper, shorten and relieve the lifter spring locators.
I forget the exact numbers, you have to make up for the .300" taller lifters.
This just fits with 3/8" pushrods.
I have run this set up for 2 1/2 seasons, 2 seasons with the Needle roller Isky Red-Zones and 1/2 a season with the EZ X rebuilt Red Zones.
Crower kit 82001
Thanks for the info. Did you have a failure with your Isky needle-type Redzones, in spite of the Rev-Kit? This is an important question regarding whether or not the rev-kit idea really offers any true benefit in general, and for Big Blocks in particular. If the Redzones did fail, is that what prompted you to switch to the EZX upgrade?ausbullet wrote: Crower kit 82001
Crower kit 82001ausbullet wrote:[quote="540 RAT
I have run this set up for 2 1/2 seasons, 2 seasons with the Needle roller Isky Red-Zones and 1/2 a season with the EZ X rebuilt Red Zones.[/quote]
I have a similar combo going together & have 82001 on the way
Do you what/know how much difference there is between the Crower 66291H16 & the Isky 372-96-RH the reason I bought 82001 rev kit was to circumvent as many fitment issues as possible.
[quote="540 RATI have run this set up for 2 1/2 seasons, 2 seasons with the Needle roller Isky Red-Zones and 1/2 a season with the EZ X rebuilt Red Zones.
Yes the cam was 'spalled' on 1 lobe the roller pin was badly worn on that lifter and the link bar was broken on that lifter. What happened first ????Thanks for the info. Did you have a failure with your Isky needle-type Redzones, in spite of the Rev-Kit? This is an important question regarding whether or not the rev-kit idea really offers any true benefit in general, and for Big Blocks in particular. If the Redzones did fail, is that what prompted you to switch to the EZX upgrade?
I believe the roller pin or the cam spalling 1st and the link bar last. NB: This was still the original cam.
There was another lifter brand was recommended and tried, unsuccessfully.
The Isky's were refitted with 1 replacement lifter and link bar, to finish out the season.
The motor was rebuilt as a 565 and the lifters were updated to the EZ X rollers.
To clarify this further, the motor was originally fitted with Crower Severe Duty roller lifters that had 5 roller pins failing just short of 1 season, picked by increase on lash on those valves. The Isky Red Zones were fitted, the motor was still in the boat, without the rev kit and ran 1/2 a season before it was refreshed and the rev kit installed.
NB: the Crower lifters were NOT the HIPPO style.
I season is 20 hours race time and another 8 hours of low load running.
The Isky's are a 'full body' design, there are not cut away behind the link bar attachment point.I have a similar combo going together & have 82001 on the way
Do you what/know how much difference there is between the Crower 66291H16 & the Isky 372-96-RH the reason I bought 82001 rev kit was to circumvent as many fitment issues as possible.[/quote
- Wolfplace
=ausbullet wrote:The Isky's are a 'full body' design, there are not cut away behind the link bar attachment point.I have a similar combo going together & have 82001 on the way
They have both, the cut away is an option
Thank you for the info on the rev kit, it is good to know the Crower plates can be modified to fit.
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
Mike,Wolfplace wrote:=ausbullet wrote: The Isky's are a 'full body' design, there are not cut away behind the link bar attachment point.
I was refering to the 372-96-RH above.
I still haven't purchased the new set of EZ X's yet, still qualifing there performance.
Up to 19 hours total, after this weekend.
Yes they are looking the goods and I will keep you in mind to order the new set.
A bit of work to fit/adapt the kit, but, I believe the rev kit helps.
Steve
- Wolfplace
=ausbullet wrote:Mike,Wolfplace wrote: =
Steve
Hi Steve,
Thought that was you but I have sent a few sets to folks your way now so I wasn't sure
I agree, a rev kit is a good idea to keep the rollers in contact with the lobes, just makes sense to me although I have a number of BB's roaming around without them, none with them & your info is appreciated as I was not aware the Crower plate could be modified to clear the bosses in the Dart blocks
When you need a set just give me a hollar, I will be glad to help
Thanks,
Mike
A tour of my shop
The Dyno
John Wayne
A tour of my shop
The Dyno
John Wayne
