52 dodge inline six
alfonso
52 dodge inline six
Post by alfonso » Sat Nov 08, 2008 11:38 am
bought a 52 dodge wayfarer and would like input on inline six
performance options
it has low comp 7-1
is there a manufacturer that makes forged pistons for it
aftermarket head or intakes
will the block handle a small turbo low boost set up
if from now on you blame anything on anybody
it might be the alien spores from the meteors...
http://www.wallaceracing.com/Calculators.htm
Masher Manufacturing
Post by Masher Manufacturing » Sat Nov 08, 2008 4:56 pm
I don't know about perf parts, but I have dealt a bit with this motor in a forklift.
There are 4 different water pumps , 2 have hub height differences by about 1/2 inch, the other 2 have different bypass / heater connections.
There are 2 fuel pumps from what I recall , one with bolts straight across, the other diagonal.
There are at least 2 crank flanges, one for manual trans and the other for auto. The auto flange is extended by about 1 inch. The torque converter nuts directly to the crank, you use a long wrench to reach between the flange and main cap.
Car usage went away circa 63, industrial use ended circa 75
Ron Golden
Post by Ron Golden » Sat Nov 08, 2008 8:51 pm
Get online and look for "Inliners.com". You can also find parts and info at the following places:
Kanters
Patricks
Egge
Several years ago I helped a tractor puller that was using a Chrysler/Dodge/Plymouth (?) inline flathead that was turboed with nitrous. I don't remember much about the engine, but it sure as hell took a lot of abuse.
Ron
Baprace
Post by Baprace » Sun Nov 09, 2008 5:37 am
alfonso, if I remember correctly there were two different flathead engines, one had a longer block that the other by about two inches, short engine came in the plymouth type cars and long engine came in the chrysler type cars.
quickd100
Post by quickd100 » Sun Nov 09, 2008 7:09 am
the long one is a 265ci. they used them in tractors combines and some of the full size Chryslers. In the Chrysler it was known as the 'Spitfire'. Dave
[img]http://img.photobucket.com/albums/v514/quickd100/9ff3c690.jpg[/img]
alfonso
Post by alfonso » Sun Nov 09, 2008 10:46 am
i believe i have the 230
offenhauser has a manifold 2x 1 barrels
anybody still grinding cams for engine
if out of perf parts the other option is
a 340 i have laying around
or
i been thinking a inline mercedes turbo diesel setup
it looks like it would fit nicely
dwilliams
Post by dwilliams » Sun Nov 09, 2008 12:25 pm
Heck, I built one of those a few years ago! Looks a lot like a Slant Six inside.
I wouldn't have any qualms about 6 to 8 PSI of boost.
Post by PackardV8 » Sun Nov 09, 2008 1:16 pm
IIRC, Edmunds, among others, made an aluminum head for the Dodge. Almost impossible to find now, but occasionally one comes floating down the bay or through the swap meets.
I second the motion to throw a junkyard turbo and water injection on it and have some inexpensive fun. FWIW, it will attract a lot more attention than just a V8 swap. If you manage to kill the sick six, the 340" option is still there for you.
What transmission do you have? Mopar was into some very perverse dead-end experiments with fluid drive in the late '40s-early '50s. These dog trannys and granny styling were the death of many very solidly built cars.
thnx, jack vines
alfonso
Post by alfonso » Sun Nov 09, 2008 3:23 pm
i believe the fluid automatic
is there a bellhousing to adapt a late model trans available
Post by PackardV8 » Sun Nov 09, 2008 8:59 pm
No idea about adapters, but the Dodge bell housing and flywheel, with three speed, 3-spd overdrive and 4-speed truck trannies were more common than fluid-drive.
thnx, jack vines
ClassKing
Post by ClassKing » Sun Nov 09, 2008 10:50 pm
Is that the six that has like an 8 inch rod? Saw one last summer and was surprised how long and whimpy the rod was.
Function - the hidden math.
http://www.pontiacengines.com
Racerrick
Post by Racerrick » Sun Nov 09, 2008 11:16 pm
I've built various displacement for forklifts and dodge trucks. You can use SBC valves in them. If I was the owner of that car I'd swap in a v8 or v10 dodge and a 518 trans
alfonso
Post by alfonso » Wed Nov 12, 2008 7:15 pm
were can i find reference materials as far as rebuilding the engine and tranny
i bought the car to learn the flathead and tuning it for performance
and my buddy as a 52 buick special with a straight 8 that i would like to surprise him with my six
Post by PackardV8 » Thu Nov 13, 2008 12:43 am
Watch eBay for a Mopar Shop Manual. An older Motor's Manual is better than nothing.
thnx, jack vines
Re:
Post by pdq67 » Mon Jul 27, 2020 12:17 am
thnx, jack vines
The old, "Fluid-Drive", the one in my '48 Dodge 5 pass coupe. I think it was called a, "Hi-Drive",??
Anyway, a fluid coupling with CPP and T/O bearing on the back of it along with a 3-speed stick tranny. Quite interesting to drive.
Clutch it, drop in 1st gear and go, no more clutching until you started over.
Boy back then when I was in college, (early '70's here), the long-haired hippies went nuts over my coupe!!
He, He!!
I think that I gave all of $80 for it?? It's still sitting up at Moberly, MO the last time I was by there.
Probably still has my old 9.50/14" mud & snow tires on the back.
