piston to valve clearance
I have a real mild cast iron headed 440 dodge, small solid cam. What is the minimum clearance you can run with on the street? It will occasionally see a 6000 rpm shift point.
[img]http://img.photobucket.com/albums/v514/quickd100/9ff3c690.jpg[/img]
Re: piston to valve clearance
.100" = intakequickd100 wrote:I have a real mild cast iron headed 440 dodge, small solid cam. What is the minimum clearance you can run with on the street? It will occasionally see a 6000 rpm shift point.
.120" = exhaust
These figures are WITH lash.
Jay Allen
CAMSHAFT INNOVATIONS
www.camshaftinnovations.com
