Crankshafts for 5.7 or 6.0" rods
I see that Eagle and Scat ect list SBC 383 cranks designed for 5.7 and 6.0" conrods. Whats the difference between these cranks? I would have thought that the cranks were the same, and any difference in rod length would be taken care of by selecting a piston with the correct compression height..
- Wolfplace
Re: Crankshafts for 5.7 or 6.0" rods
=b73 wrote:I see that Eagle and Scat ect list SBC 383 cranks designed for 5.7 and 6.0" conrods. Whats the difference between these cranks? I would have thought that the cranks were the same, and any difference in rod length would be taken care of by selecting a piston with the correct compression height..
Counterweights are larger in diameter for a 6" rod crank which makes internal balancing much easier & less expensive.
They need to be cut down for the 5.7 rod or when you get to BDC very bad things happen
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
