Actually, that was very rude of me to have phrased it as a question. I already have an opinion.
The responses in that thread ranged from "not a clue" to "I will now quote every non sequitur I can remember about engines, and flatly state that they prove my point". No one laughed when someone said (loosely paraphrased) "all race engines have the same torque per cubic inch regardless of RPM" as if compression ratio had no effect.
Quoting from my own comments:
"DCR Errors
“Dynamic Compression Ratio” (DCR) is offered (elsewhere) as a method of approximating how much power will be lost by extended intake closure (i.e., cylinder pressure is reduced). DCR is very useful in predicting what octane is needed at lower speeds to help setting idle (initial) spark vs. advance curve length, stall speed, &c. However, this is only partially accurate due to several errors and misconceptions.
1. The actual power loss is only present below the points where both full capture (where intake reversion ABDC stops) and positive flow-through at overlap occur (although these may not be close together). Above that point power is increased (over the milder cam), either by improved volumetric efficiency (and cylinder pressure, since a larger percentage is trapped in the cylinder), higher RPM reached @ the same efficiency level, or both.
2. The power loss is not solely due to reduced cylinder pressure (which is the output of the Kelley, RSR &c. DCR calculators), since the lower pressure is also acting through a shorter effective stroke (measured from intake valve closure ABDC) and therefore suffers from two reductions. My own method factors in the effective cylinder displacement as well, for a closer approximate at how much power is developed at low speed.
3. DCR is widely considered to be an accurate barometer of knock resistance (e.g., “up to 8-1 DCR can be used with XX octane”, &c.).
This is not true, and not safe, since (in a high compression motor with its DCR reduced by late intake closure) after the early low-pressure period expires (at the beginning of the torque curve) actual combustion pressure will be at least as high with the bigger cam than it was previously - even though the DCR is lower, and therefore suggests that lower octane is safe. However, in a motor with 14-1 static CR the gas pressure at its torque peak is not at all reduced by a very late intake closing point, although the (lower) DCR may indicate that 92 octane &c. is sufficient.
Since the knock will only occur at high speeds it may not be audible, and will reduce power (lower MPH) even if no damage can be detected. In my opinion, the power sometimes gained by retarding spark in high gear is actually an attempt to recover some of this loss - but would be better served by reducing the static ratio slightly.
DCR is a curve or slope of cylinder (not combustion) pressure, with Position 0 (the absolute low end) at cranking speed, then a small rise to idle speed, then another rise to the capture point &c. After this point (and especially near the torque peak) the static CR becomes more important, since almost the full stroke length is captured and compressed, regardless of the intake closing point.
Any cam will determine the “slope” (or rate of rise) of the DCR curve. A long-duration cam with its attendant late intake closing point will have a high degree of rise, a mild cam less, &c. A longer cam will also extend (stretch) the range of RPM that the slope covers, sometimes over several thousand more RPM.
The static ratio determines the height of the cylinder pressure line at Position 0 (cranking speed). With high static ratio the entire curve is higher, with the curve's upward intensity being governed by the intake closing point.
It's possible to design a DCR that looks promising, but will not provide any more power, by assuming that there is no limit to either static ratio or intake closure - and, of course, neither is true. Some motors cannot turn fast enough (due to stroke length, weak valve gear, high reciprocating weight, &c.) to reach their capture point if the intake closure is too late, and will produce more power with more conservative cam timing. A motor with limited static ratio (flathead) must conserve cylinder pressure by limiting intake closure for the same reasons.
Another error in use of DCR calculations for low-speed power prediction lies in the fact that a smaller volume of mixture being compressed to a higher ratio. Even though the pressure gauge reading taken during cranking or idling is higher, the total of cylinder pressure times the actual mixture volume captured may still be lower (compared to the original milder cam and moderate compression ratio).
To sum up: DCR a useful tool, but widely perceived to be of greater worth than can be supported by physics. "
Read the entire article:
http://victorylibrary.com/mopar/cam-tech.htm
