connecting rod, angle cut cap
dan miller
Post by dan miller »
Why do some connecting rods have the cap placed asymmetrically? Looks to be around 45 degrees.
I suppose that it transfers some of the bolt tensile load to shear, and probably allows for a little more camshaft clearance.
But, there has to be more to it than the above. Assuming "the above" is correct. lol
Thanks, Danny
miniv8
Post by miniv8 »
Its main purpose is to get the rod down the smaller cylender.
gmrocket
Post by gmrocket »
as in the british leyland A series
Post by MadBill »
A friend of mine could have used such rods a number of years ago. He came into a great deal on a bunch of stock block Buick Indy parts and started building up a class-killer engine for a 170 c.i. boat racing class. When everything had been machined and he started bolting it together, he found that the bore he'd had to sleeve it down to was too small to get the rods through... :oops:
rustbucket79
Post by rustbucket79 »
OOF!! That must have been a sad day indeed. :cry:
machine shop tom
Post by machine shop tom »
MadBill wrote:A friend of mine could have used such rods a number of years ago. He came into a great deal on a bunch of stock block Buick Indy parts and started building up a class-killer engine for a 170 c.i. boat racing class. When everything had been machined and he started bolting it together, he found that the bore he'd had to sleeve it down to was too small to get the rods through... :oops:
Truly a "DOH!" moment.
tom
Pray for a secular future.
We used to speak to tell things , now they tell things to speak.
Si Vis Pacem, Para Bellum
jake197000
Re: connecting rod, angle cut cap
Post by jake197000 »
flathead lincoln same way v-12
Many diesel engines, including the millions of Cummins 6-cyls, are this way.
mag2555
Post by mag2555 »
They also did that to make changing out bearings easier while keeping the motor in place.
Boy I wish some big ass stationary Diesel generator’s that I have rebuilt where that way!
modok
Post by modok »
Who is they?
jred
Post by jred »
just got done with a 2015 2.7 v6 ecoboost con rods are that way..
davidbraley
Post by davidbraley »
Sorry if this is a really dumb question...
How does clocking the parting line for the rod cap like what is shown above effect the bearing clearances? It's my understanding there is more oil clearance at the parting line.
I'm a machinist... because engineers need heroes too.
modok
Post by modok »
Good question.
Achieving tightest clearance in the loaded direction is one reason, but not the ONLY reason for bearing wall eccentricity.
The other reason is to counteract housing distortion from the bearing interference fit or "crush", so that's unchanged.
And another reason is to make up for flex in the housing, but a rod mainly flexes in a bad way when under tension.
Yeah having the tightest point at 45 degrees is not perfectly ideal, but it's not that bad either. No different than a 90 degree v8.
Many of these are LOW rpm, or diesel engines where the rod only sees high loads of compression, so they do not need a lot of wall eccentricity in the bearing.
