Most power out of a 23* head pumpgas smallblock?
FASTFATBOY
Post by FASTFATBOY » Sat Dec 27, 2008 9:19 pm
Whats the most anyone has seen? One that can be streetdriven.
Around 383 inches?
Anyone?
John W
Post by John W » Sat Dec 27, 2008 9:30 pm
At 383?? A friend has a N/A 10.7:1 383 thats been in the 10.2x's @3330lbs. Runs and raced on pump gas and easily street driven, yet not something I would want for daily driver with a long commute. Probably would dyno in the 580 range.
[url=http://imageshack.us][img]http://img352.imageshack.us/img352/5535/chevellehmplf4.jpg[/img][/url]
[url=http://g.imageshack.us/img352/chevellehmplf4.jpg/1/][img]http://img352.imageshack.us/img352/chevellehmplf4.jpg/1/w320.png[/img][/url]
3V Performance
Post by 3V Performance » Sat Dec 27, 2008 9:44 pm
355ci steel heads, 625hp on 93 pump gas
http://www.3vperformance.com/streetperformance.html
Track times will come in the spring when snow melts. :D
Tom
3V Performance
" ENGINES WITH AN ATTITUDE "
980-222-7230
SStrokerAce
Post by SStrokerAce » Sat Dec 27, 2008 10:57 pm
Wait till Larry shows up!
600hp is very doable.... 700hp on 23° heads is very hard!
[img]http://photos-g.ak.fbcdn.net/hphotos-ak-snc1/hs139.snc1/5928_111214857139_110806152139_2127222_6826389_n.jpg[/img]
[i]Those of you who think you know it all are particularly annoying to those of us who do[/i]- Penske garage sign @ Indy circa '71
3V Performance
Post by 3V Performance » Sat Dec 27, 2008 11:06 pm
Most power out of a 23* head pumpgas smallblock and 383ci?
700hp is very impressive indeed.
3V Performance
980-222-7230
SStrokerAce
Post by SStrokerAce » Sat Dec 27, 2008 11:24 pm
Yeah 383's don't make that easy to do!!!! Unless you make a 383 the hard way with a 3.500" stroke and a 4.155" bore! Even then with 23° heads?
FASTFATBOY
Post by FASTFATBOY » Sat Dec 27, 2008 11:25 pm
John W wrote:At 383?? A friend has a N/A 10.7:1 383 thats been in the 10.2x's @3330lbs. Runs and raced on pump gas and easily street driven, yet not something I would want for daily driver with a long commute. Probably would dyno in the 580 range.
Mine would run that at 3300lbs I think, I streetdrive it alot, it has overdrive. I wouldnt drive it everyday. If I was younger I would.
Just fishing to see if I am at the limit of what I have, Guess my next move is putting the engine/trans in a much lighter body.
I think I am around 600hp.
chevy_power
Post by chevy_power » Sat Dec 27, 2008 11:31 pm
3V Performance wrote:355ci steel heads, 625hp on 93 pump gas
Tom
Two thumbs way up tom, that's impressive! :o
Speed kills, save lives, drive a honda
3V Performance
Post by 3V Performance » Sat Dec 27, 2008 11:55 pm
chevy_power wrote:Two thumbs way up tom, that's impressive! :o
Thanks it was alot of fun. We built that engine as a circle track engine for him a few years before. He decited to change things up and do some street / drag racing so we converted it over.
Tom
3V Performance
980-222-7230
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 » Sun Dec 28, 2008 11:17 am
I have seen good 383 motors that were in the 615 to 625 range on pump gas-- No days, if you wanted more HP, why would you only build a 383 ?? Bigger is allways better
JOE SHERMAN RACING ENGINES
blakdawg
23* power
Post by blakdawg » Sun Dec 28, 2008 12:11 pm
Yea! six and a quarter on pump gas w/23*heads and a 355 no less. Very nice Tom. I'm w/ Big Joe though,if some's good more's better.You get up in that range you're gonna be needin a better block and crank anyway,why not go BIG.
jeffmckc
Post by jeffmckc » Sun Dec 28, 2008 12:17 pm
pump gas cubic inches rule the day!
2007 HotRod Drag Week Winner SB/NA
2012 HotRod Drag Week Winner SS SB/NA
Fastest/Quickest Small Block N/A
Stock Suspension Car on Drag Week since 2007
9.67@ 139 with a 1.42 60' thru the Mufflers Dot tires
Thanks RFD Heads and Intakes
FASTFATBOY
Post by FASTFATBOY » Sun Dec 28, 2008 8:12 pm
bigjoe1 wrote:I have seen good 383 motors that were in the 615 to 625 range on pump gas-- No days, if you wanted more HP, why would you only build a 383 ?? Bigger is allways better
Well Mr Joe, 383 is kinda what I ended up with. Got a killer deal on a shortblock. 396 is about the limit on a 2nd gen LT1 engine anyway. The safe limit and streetdrive it.
SO I have pretty much peaked is what I am getting from you guys?
Guess I need to leave it alone and enjoy it. Lighten the car, more converter and try to get a 10.69 out of it.
lun40119
Post by lun40119 » Sun Dec 28, 2008 9:00 pm
What about this guy..............
http://advancedinduction.com/
Whats the deal with this thing I think it is the same cube and style as your engine.............do the math I used the calculator at Prosystems.
1989TransAm
Post by 1989TransAm » Sun Dec 28, 2008 9:27 pm
The AI 383 has 530rwhp. If a 15% drivetrain loss that works out to around 625hp at the motor.
