some form of Ethanol is blended into it. i would't want to quote an exact percentage. your right...something like 10% though.greywolf wrote:Ryan,
would the fuel you are talking about be the ethanol blended premium gas.
(10% ethanol added).
Most power out of a 23* head pumpgas smallblock?
Re: mohawk/husky fuel
There are no limit's to mans' ingenuity, just as mans' ingenuity will never conquer the forces & behavior of this planet....Smokey Y.
Ryan
So is your pump gas sb2.2 motor is running 150+mph in 3000lbs with a holley 950HP? Has it seen a dyno? Would take about 800 hp to run those numbers wouldn't it? Well done anyway!
I think troy was just trying to say that the 950HP is a small (about 1.4") venturi with an 850 sized baseplate under it.
Re: -
Sorry flyin ryan, I should have also said it was impressive as it was. I was just pointing out that there was more in it.flyin ryan wrote:Troy Patterson wrote:flyin ryan wrote:
Troy Patterson TMPCarbs.net TMP Carbs
- RayJE Carburetors
Re: -
Thanks Troy, & i DO agree with you. there's more in everything. that's our game & why we're on here, right. sorry if i came off like i was too sensitive, sometimes that happens on these boards. nothing wrong with constructive criticism in my books .Troy Patterson wrote:flyin ryan wrote:Troy Patterson wrote:
Re: -
Not an SB2.2, it's a Dart Little Chief, kinda the same only different . like i was saying earlier, i've only had it down the track a few times before the wheelstand incident. ran 151 MPH, can't remember...three or four times anyways. it's the same 950 Holley HP i ran on my 395. after the wheelie i sent the carb to my guy, Bob Book, to let him have a look at it. he did a few things to it, not a bunch. i've not had it back on the dyno since the carb work though. ya...makes over 800 HP on pump gas with a Dart cast single four, the manifold is not doing me any favors, thats a fact.Fatman wrote:Ryan
BTW, i understood what Troy meant.
Thanks Ray, been pretty busy with life and working.
No problem flyin ryan. I've done the same.
Re: -
No, it'll never see a Dominator. one of the reasons is i have my air pan built into the underside of the cowl hood, so if i lift the hood all you see is carb, tough to get a perfect seal though , it's a Corvette with the factory style front hinge/rear lift hood. i use an old Hartman base that has a very nice radius (Comp bought them out years ago) that is epoxied to my hood. when i did my wheelie i busted that base all to hell. well Comp quit building that old Hartman stuff a few years ago. luckly Chris Mays at Comp was able to find a couple stashed in their warehouse, thankfully . a larger venturi 4150 is definatly an option, still have a few bugs to work out until i get to that point though.Fatman wrote:don't know why i was thinking sb2.2.
Will this motor see a dominator? or a bigger venturi 4150? I'd love to see its full potential on pump.
Have you posted about it on any other forums. I'd like to read about the build.
i posted a few things, although i didn't start the thread, i think it's under 'dart little chief vs. sb 2.2' can try that. i can e-mail you a few pics if you PM me your address, if you like.
Sorry,I don't.tod85 wrote:do you know what cam spec they are using on that ?new engine builder wrote:A well known engine builder from Ohio claims out of a 434 on pump gas with Dart 230 cc heads,hyd. roller,619 hp at 6,400 rpms and 568 lbs. of torque at 4,900 rpms.tod85 wrote:I'm curious as to what is the most power you can make with a 23 degree head with a hyd roller cam these days ? I know some of the newer extreme hyd roller cams coming from competion cams have some pretty agressive lobes.....
Thanks for the info !
I doubt he would ever tell.
23 degree head max output
flyin ryan - when it comes time, I could build you some 4150's that flowed more than 1100 cfm each. A bit unconventional, but the engine doesn't care.
Re: 23 degree head max output
Un-conventional is my middle name. I 'will' keep that in mind. thanks for the offer, TroyTroy Patterson wrote:flyin ryan - when it comes time, I could build you some 4150's that flowed more than 1100 cfm each. A bit unconventional, but the engine doesn't care.
