What port cross sections do you watch?
I'll get it started, I focus on four:
1) Pushrod
2) Top of short turn (window)
3) Bowl
4) Seat Ring
Port Dimensions Quiz
1) Pushrod
3) Bowl
4) Seat Ring
i "measure" all 4
and what i can't measure directly...i calculate what the velocity fps should be in that area .
the pushrod area choke is not as "Critical" as it used to be many years ago like on 292 turbo heads and such designs
with modern Chevy SB2, Canted Valves, etc (Jesel offest rockers/lifters)
has taken a bunch of choke off in this location
1) Pushrod
3) Bowl
4) Seat Ring
i "measure" all 4
I think that for most of us, there are usually limitations on what we can and can't do with a head depending on the classes that they are run in, rpm limitations,and buget. I have some "cheats" that i use to get me in the area that i need for min. cross section, based on the application. From there i would look at valve diameter needed for the application. or what you can stick in there,lol.After that i work my way back to the port opening. Sometimes this is an issue, like Larry had stated, with older heads or cast heads required by some classes.I hate it when you get to the point where that pushrod area is the min. cross and you can't do anything about it because of rules.The difference in velocity between the min. cross and the throat, in an open type head, usually is around 3%-5%.Again this will change depending upon application.
Shawn
Shawn
