If you check the clearance with the EOIC method and compare it to a different method the clearance could well be different.
If you set the opposite valve when one valve is at max lift the lifter will be on the edge of the opening or closing ramp and not the bottom of the base circle.
Also, at this point the force on the cam from the valvesprings is different.
Grab a cam and take a look at what is going on when you are setting valves by different methods.
Keep in mind you can waste a set of cam bearings turning the engine over without oil pressure. Turning the engine over should be kept to a minimum.
Why does valve lash change?
It appears it is a difference in how he was adjusting them. Use one method, get x amount of lash, use another, get a different amount of lash.
I went back to the firing order method and set them that way. He's been doing it for years, and it's never not worked for him. He was just wondering why there would be a difference, but the assumption was that the cam would be exact on the base circle no matter the method. It appears this is not the case.
Thanks for the replies! Very helpful info.
David_D.
74 Nova Custom Hatchback
- af2
Hard to know without seeing it.. You Have to adjust the valves 1 way and stay with it right or wrong to see changes.David_D. wrote:It appears it is a difference in how he was adjusting them. Use one method, get x amount of lash, use another, get a different amount of lash.
I adjust valves as Joe does it works for me. If I were to change that I would stay with the change to make sure the lash is the same. It sounds like you are checking in 3 different places and will never get the same #.
I meant to say the firing order doesn't work with the cam I run.
GURU is only a name.
I get eased a lot about my lash setting technique. My buddies refer to it as a "St Vitas dance" as I go from side to side with feeler gauge, Sharpie, and tools in hands.
I start off doing the IC/EO deal and put a Sharpie mark on each rocker. Then I rotate the engine a random bit and recheck the "loose ones", repeating the process for several revolutions. At this point I will not loosen one - knowing I am at least gonna have the desired clearance - but I inevitably find one or two that needs to be tighter.
Survival Motorsports
www.survivalmotorsports.com
WD for Comp, Manley, Blue Thunder, Diamond
Probe, Holley, Clevite, Federal-Mogul, Scat....
