Exhaust Port Turbulence
Godzilla
Post by Godzilla »
Hey everybody, I've got an exhaust port that has bad turbulence from .300 to .600. What should I do remove it or lower its intensity? Thanks for the help
SW
Post by SW »
Is that flowing it with a pipe on it?
Shawn
Godzilla
Post by Godzilla »
No pipe.
maxracesoftware
Post by maxracesoftware »
Shawn
Yes, that was the 1st question i was going to ask :)
what about valve job, all angles/widths
radius ?
and exh bowl diameter below bottom seat angle or seat insert?
and what exh valve head diameter ?
What percentage is throat area there -to- exh valve head diameter?
if you grind away too much on Short Turn curve can cause that
if you don't setup flow to go into exh port can cause that also
its a question that you would have to have the actual cylinder head in front of you to inspect porting and valve job specs
MaxRace Software
maxracesoftware
Shawn
Also try Flow Testing again with Pipe on exhaust port
at least 4 inches long
even with header plate adapter also if you run one
many times exhaust port is still in the process of turning when it dumps into atmosphere and can cause turbulence
flow testing with pipe can be different results as pipe helps continue on and straighten exhaust port before dumping
turn head around and flow test with headers on
see if same effect
if so
have to look at Short Turn / Valve Job
even valve margin thickness and backcut sometimes
MaxRace Software
SW
Post by SW »
Looks like you covered everything i was going too, lol.With an exhaust port being as short as it is, and as high velocity as they are, that abrupt edge will do strange things sometimes.
Have you ever used exhaust port adapter plates to "trick" and exhaust port that you couldn't grind on? We did some of that with the circle track late model guys that have to run a non ported iron head.Kind of fun stuff to play with, if you can get away with it.
Shawn
Godzilla
Post by Godzilla »
maxracesoftware wrote:Also try Flow Testing again with Pipe on exhaust port at least 4 inches long
You guys may be right - it's a Ford FE, which is really funky on the exhuast. I'll try it and let you know. Thanks
