Camshaft Help Every lobe worn down Except #1 Cylinder
camaro1974
Post by camaro1974 »
I have a 350 Small Block it has been rebuilt about 7 years ago.I
just put a new crane cam it ,I took it to a mechanic to set the valve lash
and he told me #1 cylender rocker arms dont seem to be opening te same distance as the other rocker arms. any suggestions
99R/T
Re: Camshaft Help Every lobe worn down Except #1 Cylinder
Post by 99R/T »
camaro1974 wrote:I have a 350 Small Block it has been rebuilt about 7 years ago.I
A little more info would help greatly.
What are the cam specs supposed to be? Who installed it? Roller, Flat, Hydraulic, or Solid? New lifters or old? How was it broken in? How much run time is on it? What springs are you running? Why did you switch cams?
Engguy
Post by Engguy »
Mad Crane employee last day before they shutdown.
Empty hydraulic tappets for that cylinder, and mechanical on the others?
Push rods colapsing.
Studs pulling.
Some ideas here.
cjperformance
Post by cjperformance »
?? Dont 'seem' to be opening as much. Has an actual measurement been taken?
No matter what cam/lifter type it is it needs accurate measurements, that need to be compared to the cam's spec's.
First up take a lift fig for each lobe (not valve), compare these to see if there is a prob, then go from there. Bear in mind that intake and exhaust may or may not be the same for it may have a dual pattern cam but all intakes should be the same and then all exhausts should be the same.
Cheers,
Craig.
Post by MadBill »
If you ran it at all before taking it in for adjustment, most likely it has wiped out the #1 lobe. If there's no huge lash when the valve is closed and it opens visibly less than the others, unfortunately there's really no other logical explanation.
dannobee
Post by dannobee »
How did you break in the cam? Did you use the assembly lube recommended by Crane? Did it idle at all in the first half hour of run time?
Geoff2
Post by Geoff2 »
11 year old thread....
Post by MadBill »
Geoff2 wrote: Tue Oct 13, 2020 3:35 am 11 year old thread....
:oops:
