Lunati roller lifters?
rskrause
Post by rskrause »
Anyone ever use the Lunati solid roller lifters? They look identical to Comps lifters and are much less expensive.
Richard
CNC BLOCKS
Post by CNC BLOCKS »
Lunati are Morel I beleive but check with Chris http://www.straubtechnologies.com/
Website is up and running
Machine shop tour
Monthly Specials
srv601
Post by srv601 »
check these lifters made by morel for pbm
http://www.pbmperformance.com/store.php?catId=420
RW TECH
Post by RW TECH »
If you're looking for cheap, the main-stream stuff is OK.
If you're looking for a LOT more durability than pretty much everything else that's available at a cost that is between that of a Crower and a Jesel, call Rich at (919)-464-6215 and get a set of CamFX lifters.
rskrause
Post by rskrause »
Has anyone actually used the Lunati's? They really are relatively inexpensive and if they are decent may be a true bargain.
Richard
srv601
Post by srv601 »
rskrause wrote:Has anyone actually used the Lunati's? They really are relatively inexpensive and if they are decent may be a true bargain.
Richard
how about a pic of the lifter in question? if it is a h-bar lifter-than look at someting else
the morel pro lifter is what i recommend.
contact chris straub he has great prices and knowledge on these products and is very nice and easy to work with,fast shipping
lun40119
Post by lun40119 »
I am running the lunati pressure fed solids. They are Morel, at least that is what Steve told me. These are the lifters that I have, I think they were like 550-600, cant remember. I just took them out of the block yesterday to look everything over after a 2000mile trip in 6days with the Power tour.....lifters still look brand new!!!!!!!
Jake
Team Clueless
Optimize the Compromise
norm
Post by norm »
lun40119 wrote:I am running the lunati pressure fed solids. They are Morel, at least that is what Steve told me. These are the lifters that I have, I think they were like 550-600, cant remember. I just took them out of the block yesterday to look everything over after a 2000mile trip in 6days with the Power tour.....lifters still look brand new!!!!!!!
in the vid it doesn't look like there is any oil up top at the rockers.
lun40119
Post by lun40119 »
It gets there, it just takes time.........but that was the same thing I thought when I primed it the first time????? Good eye....
Jake
Team Clueless
rskrause
Re: Lunati roller lifters?
Post by rskrause »
Update to this old thread: I have been using the Lunati lifters and in my bracket motor (relatively low stress) they have been fine. I am using the original set again this year as I could find nothing wrong with them on close inspection.
Richard
