Page 2 of 3
Re: Can I use (stock) Ford 351C HEADS on my Ford 302 ('79) Block
Posted: Fri Feb 19, 2010 2:55 am
by ProPower engines
Just wondered if there is a "factory cast iron" intake" that fits these heads?
Posted: Fri Feb 19, 2010 9:59 am
by job1bf
I would imagine a BOSS 302 intake might be the only factory option, but they were aluminum dual plane manifolds...
Posted: Fri Feb 19, 2010 12:31 pm
by fishman
Years ago i found a set of boss 302 heads and intake and decided on making a boss 302 well i couldn't find a block so i used a 289 block when i tried to bolt the heads on the holes in the block were smaller then the head bolts so i had to get a set of bolts with a 7/16 shank and 3/8 threads that were special ordered....i am not sure but i would think on the 351c heads you have the same problem...........
Posted: Sun Feb 02, 2020 3:25 pm
by SupStk
fishman wrote: Fri Feb 19, 2010 12:31 pm Years ago i found a set of boss 302 heads and intake and decided on making a boss 302 well i couldn't find a block so i used a 289 block when i tried to bolt the heads on the holes in the block were smaller then the head bolts so i had to get a set of bolts with a 7/16 shank and 3/8 threads that were special ordered....i am not sure but i would think on the 351c heads you have the same problem...........
Not quite correct. The Cleveland heads used 1/2" head bolts while 289-302 Windsors had 7/16. Edelbrock, AFR, ARP and possibly others offer stud and bolt kits with stepped washers which make that aspect of the swap a non-issue.
Posted: Tue Feb 04, 2020 8:12 am
by Steve.k
ProPower engines wrote: Fri Feb 19, 2010 2:55 am Just wondered if there is a "factory cast iron" intake" that fits these heads?
Tim meyer sells trackboss intake to exactly fit this setup. You will need new pistons and also tap and plug front water passage in head. The heads will increase where you make peak tq and hp but will likely net big gains over windsor style head. That said i have made easy 425 hp on 351 cubes at 5900 rpm. So not spinning very high. 302 wouldn’t be much higher.Most canted valve heads are not allowed in dirt tracks here so may wanna check rules in your area. https://www.tmeyerinc.com/product/track ... -manifold/
Posted: Tue Feb 04, 2020 12:35 pm
by 1972ho
If you want to know a little more on this set up go over to the 351cleveland.net on Facebook and check with some of those guys they have some circle track racer over there that can give you some advice.
Posted: Tue Feb 04, 2020 1:39 pm
by Steve.k
Yes H.o is correct some good recipes over there. Contrary to popular belief the 4v Cleveland head can and will make good power at lower rpm. And a hell of alot more at high rpm.
Posted: Tue Feb 04, 2020 3:54 pm
by Joe-71
Why not use the N-352 iron Motorsports heads? They are the "go-to" heads for the roundy-round guys locally. Joe-71
Posted: Wed Feb 05, 2020 2:02 am
by fishman
SupStk wrote: Sun Feb 02, 2020 3:25 pm
Sorry yes you are right it is 1/2 head with 7/16 threads. I built that motor in the mid seventies so memory is a little off. I used boss 302 pistons , rods and crank also stock intake. A guy blew up his boss 302 and he sold me the carb,heads,intake and valve covers for $115 I jumped at it
Posted: Wed Feb 05, 2020 4:46 pm
by ProPower engines
Years ago there was an intake made from cast iron made by a company for this swap but they went out of the biz.
Not enough volume of sales killed the project. I have seen that intake and it was not a bad piece either for guys that had to run cast iron for a class rule deal.
There is other intakes that can be used as the 351/400 M head is a close relative to the cleveland head.
There are a few ford guys locally here that have done the swap on a 302 and 351w and made really big numbers with the iron heads. While the stock heads are a ton of work to fit an intake to they seemed content to go that route and made reliable power.
Posted: Wed Feb 05, 2020 8:56 pm
by Steve.k
The windsor heads return coolant through the intake and not the block like Cleveland. The 351m and 400 blocks are 10.29 deck so you would have to cut if even possible to fit 8.2 302.
Posted: Thu Feb 06, 2020 10:50 am
by Truckedup
When the C engine was available in 1970, there were 2bbl and 4bbl heads with different port sizes?
Posted: Thu Feb 06, 2020 12:01 pm
by ProPower engines
Steve.k wrote: Wed Feb 05, 2020 8:56 pm The windsor heads return coolant through the intake and not the block like Cleveland. The 351m and 400 blocks are 10.29 deck so you would have to cut if even possible to fit 8.2 302.
Its totally possible.
Cometic head gaskets solve the water flow issues. He drilled the 302 block for 1/2" head bolts that was a PITA but doable.
Intake spacers to get the manifold to fit and a little imagination for the cooling system and away to the races he went.
I know he did one engine with ported 2bbl cleveland heads and it hauled ass with the best of them.
Posted: Thu Feb 06, 2020 1:59 pm
by dannobee
Truckedup wrote: Thu Feb 06, 2020 10:50 am When the C engine was available in 1970, there were 2bbl and 4bbl heads with different port sizes?
Yup. And there are also open and closed chamber heads. Just to add to the confusion.
Posted: Sun Feb 09, 2020 7:24 pm
by cjperformance
ProPower engines wrote: Thu Feb 06, 2020 12:01 pm
Regardless of head gaskets used you still need to block/seal the coolant to block return holes in cylinder head, and then drill the head either for coolant flow return thru the intake manifold like a W runs OR drill the front of each head for an external coolant return.
