coated bearings
bsfc9
coated bearings
Post by bsfc9 »
can anyone comment on how coatings on bearings affect clearance? can they be run tighter than usual?
speedtalk
Site Admin
Site Admin
Post by speedtalk »
In the past I was forced to use coated bearings and I hated it - the thickness was inconsistent, it would wear and sometimes even flake off. It made it impossible to trust your clearance numbers. As for your question, yes, I'd run them tighter.
In Memory of Don Terrill
SpeedTalk Owner/Admin
user-z68766209
coating
Post by user-z68766209 »
Coated bearings for years in house used Techline Coating
Set the clearance you wanted then coated bearing.
Would end up adding .0003 per half.
Brian B
