alky vs. gas
grant6395
alky vs. gas
Post by grant6395 »
ok here it is..i bought one of those sv1 carbs from patric james(pro systems)the alky version.1100 cfm or so.i had one of his 1050 domnators .(gas)worked well. here is my question.i belive the design of the sv1 will make more and usable power through the curve,but how much can a guy realisticaly expect to gain or loose going to methanol once properly tuned .the combo is a 443 ci windsor ford.864 :?: hp on c16 vp.
14 to 1
7721 victors 396 fpm@.850 LIFT.
BULLET CAM 286/294@.050 109lsa..105icl.
edelbrock 2828 manifold.flowed on head.4 middle runners 394fpm/4 outer runners 390fpm.
4 stage dry sump
vacuum pump...limited to14 in.vac.
let me know if you guys have any experiance with meth.vs gas..
thx
grant
RednGold86Z
Re: alky vs. gas
Post by RednGold86Z »
Several percent by fuel change alone.
W. Tripp
Re: alky vs. gas
Post by W. Tripp »
Simply changing from gas to methanol can gives gains of 4-5% in many aplications. If the ports are matched for the larger volume of fuel, a bit more can be had. If not, the engine will peak a few hundred rpm lower.
If you take full advantage of the cooling effect of methanol, there is a bit more to be had.
CamKing
Re: alky vs. gas
Post by CamKing »
Depends on compression, but with your 14:1, you should see a 5-6% gain.
dfree383
Re: alky vs. gas
Post by dfree383 »
Motors with poor heads can see larger gains.
raynorshine
Re: alky vs. gas
Post by raynorshine »
W. Tripp wrote:Simply changing from gas to methanol can gives gains of 4-5% in many aplications. If the ports are matched for the larger volume of fuel, a bit more can be had. If not, the engine will peak a few hundred rpm lower.
x2, my experience exactly :-"
Use it up
Wear it out
Eat it all!
-the greatest..."Dale Armstrong"
Moparious Maximus
Re: alky vs. gas
Post by Moparious Maximus »
I dont know about carbed alky, but I switched a 12 to 1, 440 mopar from carbed gas to injected alcohol and the car picked up 5 tenths. Alcohol is well worth it, no more water, runs cooler, cheaper, more power, more consistant and its way easier to tune.
I will never run gas again.
1963 Plymouth S/FX, 3215lbs, straight axle, best time 7.99 @ 170mph
572" mopar wedge, 8-71 @ 28% over on alky, glide, dana 60, 31.25X12 slicks.
http://www.youtube.com/watch?v=vq-xzFWHtFk&NR=1
grant6395
Re: alky vs. gas
Post by grant6395 »
sounds like a cool car..must make lots of seeds to push that weight that quick..let me guess ..around 1450 or so??
grant6395
Re: alky vs. gas
Post by grant6395 »
anybody else have any experiance with the pro systems alky SV1??let me know more if you have.
need more alky info.were dynoing in a week or so ,back to back comparisons,so i can let you know after.need more info on a/f and bsfc for methanol.
thx
grant
JBV-HEADS
Re: alky vs. gas
Post by JBV-HEADS »
On the back to back, expect 10-20% in the 3000-5500 rpm range and depending on chamber design and available CSA in the ports, -5% to 10% on the top end. Speed of the burn has the most effect on the top end numbers. In restricted motors the oxygen in methanol will allow us to gain 25-30% on the top end depending on rules. I hope you feel free to post the % differences. These number are extremely consistent. Good luck,
Joe
ClassicComp
Re: alky vs. gas
Post by ClassicComp »
Have seen no gain IN GOOD AIR from a 468 iron head BBC w/tunnel ram x2 660's to a Flying toilet.
135mph gas 135mph alky 9.75 ets
results speak for themselves
Budnicks
Re: alky vs. gas
Post by Budnicks »
I ran an alky injected altered in the mid 90's used about 170% the amount of fuel & larger nozzels buy about the same % larger pump & lines & about 3 tenths when runing in the 7.90's range before w/ERC 116 I think, don't remember what gas but went into the high 7.50's first run on alky had to inlarge all fuel components to accomadate the alky but was cheaper per gallon, ran cooler like 50 deg.s, had to warm up in pitts before every round, could hot lap all day, the only down fall is verry corrosive had to drain fuel system after every pass to not get oxedation on all aluminum parts in fuel system that woud clog the nozzels, switched to stainless fittings & could make it thru the day at least then drain & run gas thru system to keep form cloging everything up with what I was told was oxidized aluminum & other aloys in the fuel system, Budnicks
Moparious Maximus
Re: alky vs. gas
grant6395 wrote:sounds like a cool car..must make lots of seeds to push that weight that quick..let me guess ..around 1450 or so??
We really dont know how much power its making, too much for the car to use, in good air I bet we could make close to 1600 with a good and nasty tune.
Alky is a little corrosive to fuel systems, aluminium is the most affected but top-lube helps and a with little post race maintanance you wont have a problem.
grant6395
Re: alky vs. gas
Post by grant6395 »
yes..thats a topic ide like to touch on..fuel system maintenance with alcohol..heard lots,dont know who to belive.HELP.
RednGold86Z
Re: alky vs. gas
grant6395 wrote:yes..thats a topic ide like to touch on..fuel system maintenance with alcohol..heard lots,dont know who to belive.HELP.
pooh, just lost a post... Anyway, we do an OEM methanol/gasoline EFI dual fuel (4 gasoline and 4 methanol injectors) system in China - and it's 0 maintenance, except you should use the lube additive. The pump manufacturers took a while to figure it out during the development stage, but now it seems fine.
Moral is - if you can get the parts made from the right materials, it'll hold up pretty well. If not, I'm not much help.
