Page 1 of 3
Valve adjustment for dummies?
Posted: Sat Oct 23, 2010 7:14 am
by speedphreake
Can someone give me a detailed simple way to adjust valves correctly? How far should the exhaust be open or how far from closed should the intake be? Seems the harder I try to get it right, the worse I seem to do.
Re: Valve adjustment for dummies?
Posted: Sat Oct 23, 2010 8:57 am
by technicaltom
http://www.youtube.com/watch?v=89o5rLpbCgI&feature=fvw ." Google is your friend ", Boxwrench Videos on YOU TUBE, are just one of the many excellent valve adjustment tutorials .Second thing here is that practice makes perfect, so spend some time and maybe get some friends to get involved .On this side of the pond us older mechanics used to use the rule of " 9 "when adjusting "tappets " as we describe the task , on 4 cylinder engines.The procedure was when number one valve closed then adjust valve number eight 1+8 = 9. Then number two closed ,adjust number seven , 2+7= 9 and so on.
by ZIGGY
What's happening? If your lash is walking around, it's not necessarily because of your adjustment technique.
Posted: Sat Oct 23, 2010 12:00 pm
by Boz-Race Engines
i do it like this: when exhaust is 1/4 the way open adjust the intake, when the intake is 3/4 closed adjust the exhaust. that way you are always on the base circle.
Posted: Sat Oct 23, 2010 1:28 pm
by CamKing
If you want the 100% full proof "valve adjustment for dummies", do each valve one at a time.
What ever valve you are on, turn the engine over until the valve is at max lift, then turn the engine over 360 degrees and set that valve.
This puts you dead center on the base circle, with zero chance of being on the clearance ramp.
Posted: Sat Oct 23, 2010 7:29 pm
by F-BIRD'88
Boz-Race Engines wrote:i do it like this: when exhaust is 1/4 the way open adjust the intake, when the intake is 3/4 closed adjust the exhaust. that way you are always on the base circle.
Don't know where you got this method but it is sure to get a bad result.
Intake closes (just arrives on seat), set the exhaust....exhaust opens ( just begins to open), set the intake. Repeat as necessary.
Setting and locking the poly locks takes a bit of practice to get it right.
Posted: Sat Oct 23, 2010 7:32 pm
by pdq67
Or do it the old messy way running at hot idle using either "the spin the p/r between your thumb and finger" method or using a pair of feeler gauges like the old Mechanics taught me way back when I was a pup!
Posted: Sat Oct 23, 2010 8:41 pm
by MadBill
Are you confused yet, speed?
The longer the 0.001" duration of the cam, the shorter the base circle and the more critical the cam's position when setting lash. if you sketch out the open/close events on a 720°-long event line, all will become clear. Short answer: If you want a no-brainer, perfect cam position every time, at the expense of a little more rotating of the engine, use CamKing's method. For any cam that I've encountered, setting the intake when the exhaust
just starts to open and the exhaust when the intake
just hits the seat does the job with a goodly number of degrees rotation tolerance. (besides, I find repeating the mantra: "Intake opening, exhaust closing." very soothing. OMMMM....
It would be very worthwhile at first to go through the sequence carefully, then without looking at the selected feelers, check for correct 'pull' on each valve a time or three and then see if you came up with the same clearance. (FWIW, a story going the rounds a few years ago was that at a Motorsports conference, a number of Pro builders were asked to lash an engine to 'X' & 'Y' cold lash, and the results were checked with a dial test indicator. Apparently the results varied by ~ +/- 0.005"...
Posted: Sat Oct 23, 2010 9:50 pm
by treyrags
If you really want to get it right, do it like Mike suggested or use the "previous intake-next exhaust" method. For example on a SBC following the firing order: when #1 is TDC adjust previous intake of the firing order (#2) and the next exhaust of the firing order (#8). Turn 90* so that #8 is at TDC - prevoius intake is #1, next exhaust is #4 and so on ....
Posted: Sat Oct 23, 2010 9:55 pm
by brket racer
Posted: Sat Oct 23, 2010 10:19 pm
by MadBill
Err.. I'd condense the method F-BIRD and I described as: I.O.E.C.: Set the Intake as the exhaust Opens, set the Exhaust as the intake Closes.
Posted: Sun Oct 24, 2010 7:58 am
by speedphreake
I've been using the IOEC method, but then I read somewhere the intake had to be partially open an a certain amount and exhaust not closed all the way. I'm going to go back to basics, then recheck it with camking's method. It's been awhile since I had to lash a motor and have had a hell of a time. Thanks.
Posted: Sun Oct 24, 2010 8:44 am
by rally
Using firing order method, very simple. I do this with my race engine. #1 CYLINDER, on firing order. Adjust both valves, intake and exhaust, turn 90 degrees, adjust this cylinder, and so on.
Posted: Sun Oct 24, 2010 9:46 am
by Boz-Race Engines
F-BIRD'88 wrote:Boz-Race Engines wrote:i do it like this: when exhaust is 1/4 the way open adjust the intake, when the intake is 3/4 closed adjust the exhaust. that way you are always on the base circle.
bullshit how do you work that out?? you obviously didnt read my post properly. have a look where the lifter is on the cam with my method. i will tell you! on the base circle thats where!. youve basicaly repeated what i said lol.
Posted: Sun Oct 24, 2010 10:25 am
by MadBill
The difference between your methods, '1/4 lift' Vs. 'barely off/almost on the seat', is likely ~ 30° for a typical cam. For most cams the difference won't matter, but the 'barely' spec gives more latitude for positional error without getting tripped up by the beginning/end of a long slow ramp on a big cam.
