Best 23' SBC head?
Guest
Best 23' SBC head?
Post by Guest »
for 400ci and 6500rpm. Thanks
Guest
Post by Guest »
Street/Strip
Gasoline
4000-6500
Thanks
tk
Show Guest
Show Guest
Post by tk »
cstraub wrote:My choice would be an Iron sportsman II with 64 cc chambers. Mild clean up, good performance valve job and the head makes alot of bang for the buck.
If you prefer alum. I would go with the small canfield. Alot of bang for the buck.
Chris
I agree or Dart Iron Eagle are very simular too.
Tom K.
www.tkrace.com
tkracehead@hotmail.com
I love motorsports because all other sports require only 1 ball!
Cheap...Powerful....Reliable...Choose only 2 of the 3
Racer7088
Post by Racer7088 »
I would say 23 degree RR Pro Actions if you have to use 23 degree heads.
Also the AFR 227 is pretty good for a regular port 23 degree.
Erik Koenig
Houston, TX
http://samracing.com
http://HKRacingEngines.com
Racer7088
Post by Racer7088 »
Oops,
didn't see the only 6500 rpm but these heads would still be great with smaller cams. You could certainly use a 200-220 cc Pro Action too for a lower performance engine like that with some clean up and a larger cam.
Erik Koenig
Houston, TX
speedtalk
Site Admin
Site Admin
Post by speedtalk »
Hey Erik,
Thanks for joining the forum.
In Memory of Don Terrill
SpeedTalk Owner/Admin
tk
Show Guest
Show Guest
Post by tk »
Racer7088 wrote:I would say 23 degree RR Pro Actions if you have to use 23 degree heads.
I've never worked on Pro Action heads since my main stream is imports around here.
Is it true they can flow up to 420+ cfm and if so with what size valve?
I think they make a head for Honda's too :roll:
Thanks
Tom K.
www.tkrace.com
sw
Post by sw »
Just spent all day on the dyno with a combo that is very similar to what you are looking for. We used the pro-topline 200cc aluminum heads.With port work these things were amazing. Better than any 200cc head I have ever seen.This motor, with a little over 9-1 comp. made over 400 ft lbs from 2600-6300 with peek torque of 517@4600 and peek power of 518@5800. It held power above 500 to 6300 and still had 486 at 6600.We were pretty pleased with the results. It idles at 750rpm and is really crisp. The motor is getting shipped to Peru, so we might not get any track results right away.Does this kind of fit what your looking for?
TK, yes, those big rolled over protoplines will go over 400cfm. Like anything else, people want to stretch the numbers some, but they are a killer head and make great power.
Shawn
Racer7088
Post by Racer7088 »
Thanks Don. It's good to be here!
There are some race versions of SBC heads that Pro-Topline makes that go over 400 cfm for large circle track and sprint car engines like their 14 degree heads and their other 11-13 degree stuff too but they're far from the 23 degree!
Erik Koenig
Houston, TX
Racer7088
Post by Racer7088 »
Chris, everyone says that but several people have told me someone else is buying them out or something?
Erik Koenig
Houston, TX
dirtnap
Post by dirtnap »
A&A Midwest ,Enginequest has got ahold of that deal after all the legal troubles.I think its going to be called EQ Lightning .
Guest
Post by Guest »
Wow well that really sucks!
SW
Post by SW »
Any word on what is going to happen to all the molds and equipment? Will it be auctioned off?
Shawn
SW
Post by SW »
Shawn
