What happen--double post almost--hope I get a new notebook for Xmaz
JohnnyB wrote:Dodge Freak wrote:If an engine spins 6,000 rpm;s that is 100 times a second--if my math is correct. Every 2 times the engine turns over the plug should fire. So 50 times each second the plug should fire @ 6,000 rpm's.
If 5 out of those 50 times a second the plug should fire but does not it will cost power. There is no way you could feel the misfire I can't believe.
Would a scope show it ?
I agree. If you are misfiring you will for sure be losing power. I would bet money that 95 percent of motors that are misfiring ARE NOT doing it due to plug problems. The plugs might get blamed, however the plug cannot fire if it isn't getting proper voltage and amperage. Then the plugs foul, people pull plugs, see fouling, and replace the plugs...........until they foul again. Then the cycle stars over till somebody discovers the real culprit, coils, distributors, electronic boxes gone bad, or fried wires. The plugs get blamed because they are the easiest to see, and generally dont cost as much as the rest of the junk.
Brand new plugs should fire a bit easier--least while they are still new.
Some spark plugs might fire even easier vs other brands, if so, they should make more hp when you have a less then perfect ignition system.
MSD tech told me when I asked how their 7al box would be OK for street use, the tech guy said oh sure and same with the better MSD 8 box, with the right coil its great for even the street.
Those higher end boxes need top notch everything else or a misfire will happen. I had a crack plug boot once and the engine during light throttle was fine but missed when I started to floor it. The wires were pretty new so I swap to my old MSD 6 box. The problem went 100% away. Drove it for a few days to make sure and then sent the MSD 7al box in for repair.
3--4 weeks later it comes back as is, no problems found. I was like huh, put the 7al box back on and same old problem. I was pissed and yelled at MSD how come you didn't fix my box.
The tech guy got me to clam down and explain whats going on, he then said I got a leak in the spark somewhere and the 6 box isn't strong enough to find the leak but the 7 box can. To take each wire off and bend them and look for cracks, sure enough I seen the crack boot and with some black tape the problem was gone.
That was the 7 box, the 8 box is stronger yet but then you need larger dist caps to space the terminals farther apart or problems like the 5--7 cylinders could crossfire and blow a hole in a piston.
I did notice the engine cold idle was better-stronger with the 7 box vs the 6 box. The sales guy at Summit told me I was wasting money buying the 7 box vs the 6. I think he was wrong. Bet he would had sold me $8 a piece spark plugs
