Whats Your Definition of a Engine Builder
Malvn
Post by Malvn » Mon Feb 28, 2011 10:09 pm
I often wondered what many consider the definition is of a engine builder??
Mike Rogers
Re: Whats Your Definition of a Engine Builder
Post by Mike Rogers » Mon Feb 28, 2011 11:07 pm
Some one who designs ,machines and assemble the engine.
Mike Rogers
215-674-5240
EQ Cylinder Heads
http://www.rogersperformance.com
jl4049
Post by jl4049 » Tue Mar 01, 2011 3:55 am
Someone capable of assembling an engine, correctly checking tolerances and clearances, machining where necessary to correct where less than optimal, able to do this for more than one type of engine and actually get it right 99% of the time (no one is perfect, I don't care who you are, everyone screws up once in a while. A good engine builder will stand behind his work and if he has screwed up, will put right).
I.E someone who can actually do more than bolt a bunch of catalog parts together.
Some of the above guys have a genuine love of a particular type of engine, these are the ones I use if I have a choice as they are more inclined to be able to help out after the initialbuild a little more :)
clevo
Post by clevo » Tue Mar 01, 2011 4:05 am
[quote="jl4049"]Someone capable of assembling an engine, correctly checking tolerances and clearances, machining where necessary to correct where less than optimal, able to do this for more than one type of engine and actually get it right 99% of the time (no one is perfect, I don't care who you are, everyone screws up once in a while. A good engine builder will stand behind his work and if he has screwed up, will put right).
Some of the above guys have a genuine love of a particular type of engine, these are the ones I use if I have a choice as they are more inclined to be able to help out after the initialbuild a little more :)[/quote
Totally agree with the above ! X2 =D>
Downunder
Dragsinger
Post by Dragsinger » Tue Mar 01, 2011 5:29 am
in addition, a person who has years of practical experience. A person who can build a complete engine package with all accessories. Then when that engine package is put to work on the track or on the street it will perform as expected. A person who really understands why/how combinations perform.
And very important, a person who has a large network of suppliers and "go to" connections that allow him access to the required parts, machine work and information. He will be a trustworthy person with a good reputation of successful builds.
wjnielsen
Post by wjnielsen » Tue Mar 01, 2011 5:44 am
clevo wrote:
jl4049 wrote:Someone capable of assembling an engine, correctly checking tolerances and clearances, machining where necessary to correct where less than optimal, able to do this for more than one type of engine and actually get it right 99% of the time (no one is perfect, I don't care who you are, everyone screws up once in a while. A good engine builder will stand behind his work and if he has screwed up, will put right).
X3. I'd say that's the definition of a competent engine builder. Don't know how it could be put much better.
-Bill
seduce the attractive... charm the rest
CNC BLOCKS
Post by CNC BLOCKS » Tue Mar 01, 2011 7:34 am
Mike Rogers wrote:Some one who designs ,machines and assemble the engine.
X2 and guys who have to farm everything and do no machine work or buys everything out a box I would call an engine assembler.
There is surly a differance between the two.
This should be a good debate!!!
Website is up and running
http://hinksonautomotive-cncblocks.com/
Machine shop tour
http://hinksonautomotive-cncblocks.com/shop-tour/
Monthly Specials
http://hinksonautomotive-cncblocks.com/specials/
55MM babbit cam bearings with 1 hole
uncle paul
Post by uncle paul » Tue Mar 01, 2011 7:56 am
If someone is willing to "build" you a motor for alot less then anyone else RUN!
2X with Carl adding in that an assembler does always know how to tune a motor correctly.
k-star
Post by k-star » Tue Mar 01, 2011 8:11 am
Does the guy have a build sheet with all the spec's, parts etc???
Does he own measuring equipment to check bearing size,cam location,rod stretch, etc??
Can he give you names and numbers of past customers??
What is the overall look of the shop, clean, crusty? (don't mix up clutter or alot of work laying around with dirty)
Some of the things I tell guys to look for. I think there are a few guys with-out equipment that are good builders, but are few and far between. I also know that there are guys with shops full of equipment that should not be building engines.
I rememebr a long time ago I was building a engine on a Saturday afternoon. I had an issue with a bearing or something I can't remember exactly what it was. I called a few of the local HEROS at that time and asked them what I should do. All of them said just run it, the guy will never know. That really stuck with me on how ASSEMBLERS think. I had to let it sit till I found the correct answer for the issue. I could never have left an engine leave with my name on it, knowing something was not right. I guess thats how I view the difference between the two.
Keith
“If I hit you with this you’re going to be numb, that’s why they call them numb-chucks “Si Robertson
donc
Post by donc » Tue Mar 01, 2011 8:30 am
someone who is way underpaid
Keith Morganstein
Post by Keith Morganstein » Tue Mar 01, 2011 8:54 am
Add to all that:
Someone that takes a whole bunch of parts that don't really fit together, modifies, massages, makes a few pieces, then gets it all to work and wins with the results.
sam-missle
Post by sam-missle » Tue Mar 01, 2011 9:35 am
Keith Morganstein wrote:Add to all that:
Very well said.
SAM-MISSLE
SOUTHERN AUTO MACHINE
931-728-7800
CamKing
Post by CamKing » Tue Mar 01, 2011 9:59 am
Someone who can degree in a cam.
ap72
Post by ap72 » Tue Mar 01, 2011 10:54 am
CamKing wrote:Someone who can degree in a cam.
I did my first one when I was 15 with a degree wheel I made myself with a couple of drafting tools and a piece of sheet metal. I HOPE an engine builder has to do more than that.
LOL, according to the post count I'm an "expert." The only thing I'm an expert at is asking questions.
SchmidtMotorWorks
Post by SchmidtMotorWorks » Tue Mar 01, 2011 11:13 am
Maybe I missed it but I didn't see any mention of:
Correctly choosing a set of compatible parts to make an effective combination for a specific performance goal.
