Howards cams
nabx22
Howards cams
Post by nabx22 »
Whats everybody think about howards cams.Especially the solid roller line they have.
T-flow
Re: Howards cams
Post by T-flow »
Have used them many of times. Great product and no problems!
T-flow
T-flow Cylinder Heads
www.tflowheads.com
topfuelrocket
Re: Howards cams
Post by topfuelrocket »
Never used there cams but
Inspected the HYD Roller lifters for a customer.
They are very inexpensive.
Have seen axles walk out on other inexpensive HYD Roller lifters
Just be aware, some times its not all about price, would like to see more feed back on Howards products
Pro 48 Fleetline
Re: Howards cams
Post by Pro 48 Fleetline »
Heard good things about them aswell! great cam for the coin!
ALKYAL
Re: Howards cams
Post by ALKYAL »
Some grinds are genuine UltraDyne [from Harold B.] He also did some refinement of some of his original designs that are now being sold by Howards. The real question is what or whos cores are they using. One of the employees who worked for Arrington engines in Martinsville,Va. now works @ Howards. [Custom Cams a div. of Arringtons was for a while the place to get Harolds designs] They also have some VERY GOOD grinding and inspection equpt in-house.
Some people are so stupid that they dont even know it! - by a famous Hillbilly
Notalent
Re: Howards cams
Post by Notalent »
topfuelrocket wrote:Never used there cams but
I find that odd as Morel is building there Hyd Roller Lifters....must have been a street model you were looking at? I wouldnt doubt it....same as any other companies street lifter...
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
CUSTOM BUILT STREET/STRIP & RACING ENGINES!
ALKYAL
Re: Howards cams
Post by ALKYAL »
Morel [here in Cleveland,Ohio] builds lifters for MANY camshaft companies. They privite label their names on the tie-bars in black laser etch.
Ben H
Re: Howards cams
Post by Ben H »
ALKYAL wrote:Some grinds are genuine UltraDyne [from Harold B.] He also did some refinement of some of his original designs that are now being sold by Howards. The real question is what or whos cores are they using. One of the employees who worked for Arrington engines in Martinsville,Va. now works @ Howards. [Custom Cams a div. of Arringtons was for a while the place to get Harolds designs] They also have some VERY GOOD grinding and inspection equpt in-house.
We have some of Harold's designs that came with the purchase of Custom Camshaft Company also a few new ones for some long-time customers of his that we recently made parts for. All the standard part number cams are designed in house.
We buy cores from EPC, Camshaft Machine, Callies, some from Cam Motion and LSM. Odd or prototype cores are often made in house or locally (70mm 9 bearing things and other oddities). I've received samples from a few foreign companies but we are reluctant to use them do to inconsistency in quality. Every cam is ground in house, and Michael (Dacaman) and family did move from Martinsville,Va to work with us at Howards.
Ben Herheim
Howards Cams
http://www.pinnacleflycutter.com/
CREngines
Re: Howards cams
Post by CREngines »
ALKYAL wrote:Morel [here in Cleveland,Ohio] builds lifters for MANY camshaft companies. They privite label their names on the tie-bars in black laser etch.
I cant verify this but im pretty sure they make all Comps lifters. Can anybody confirm that?
CamKing
Re: Howards cams
Post by CamKing »
No, they do not.
SKeown
Re: Howards cams
Post by SKeown »
I was told by Johnson Lifters that they make hydraulic rollers for Comp Cams.
SKeown
