Don, Great forum for the hardcore gearheads! Get in touch with Scooter at Comp or Harold at Superflow. They could make a link from the AETC.
Anyone out there see any reduction in friction from any of the cylinder wall coatings?
Cylinder wall coatings
- New Member
If you always do what you have always done,you will always get what you always got.
Hi Rich, thanks for joining the forum. I've used Nikasil before. The payoff seamed to be the wear resistance. Not sure if it's worth the cost and hassle. Maybe someone on the forum has used it more than I have.
Thanks for reminding me, I need to get someone from Comp on the show.
In Memory of Don Terrill
SpeedTalk Owner/Admin
I now a few years ago engine builders were putting in composite sleeves
with the nikisel coating, Steve at LSM systems was doing a lot of that work I beleive it was about 800 dollars a sleeve plus machine work to install them.
Website is up and running
http://hinksonautomotive-cncblocks.com/
Machine shop tour
http://hinksonautomotive-cncblocks.com/shop-tour/
Monthly Specials
http://hinksonautomotive-cncblocks.com/specials/
55MM babbit cam bearings with 1 hole
Machine shop tour
Monthly Specials
Its only in tenths and diamond stones are required to hone the cylinders and the reson for the composite sleeves they are about half the weight of a std sleeve.learner wrote:I've never messed with cylinder coatings except for a couple motorcylcle cylinders. How thick are the coatings and what stones do you use to hone them with?
Thanks
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
