You bring up an important point Cobra, and your numbers are bang on, but rocker construction details don't affect results, it's all down to the ratio. For simplicity, assume the rocker's pushrod seat to pivot/fulcrum measurement is 1.0" and the fulcrum to valve stem contact point length is 1.50" for a total length of 2.50". In normal operation the rocker acts as a 'first class lever', therefore the ratio is 1.50/1.00 or 1.5:1, so 0.025" plunger pump up would translate to holding the valve 0.0375" off the seat.Cobra720 wrote: ↑Thu Jan 26, 2012 5:42 pm... My lifter plunger movement is .040 for a 1/2 turn on an ARP 7/16-20 with a 1.6 scorpion rocker. The actual screw movement on the stud is probably .025. The distances of rockers from center to roller and center to pushrod cups are different from brand to brand. The ratios may be 1.6 but makeups are all different.
When the adjuster nut provides the motion however, the rocker becomes a 'third class lever' with the valve stem as the fulcrum and so the ratio of plunger to adjuster motion is 2.5/1.5 or 1.67:1, thus 0.025" adjuster movement equals 0.025" x 1.67 = 0.042" at the pushrod.
https://en.wikipedia.org/wiki/Lever
