panic wrote: ↑Mon Feb 13, 2012 12:20 am
Against my better judgment, I'll ask:
what does the rod's center of gravity have to do with reciprocating vs. rotating weight?
Suppose we were to weigh a con rod and then balance the rod on a knife edge.
By measuring the location of the balance point, we can determine the weight of the
big end and the small end. They might be 50-50, but probably not. The small end weight
can be added to reciprocating weight and the big end weight added to the rotating weight.
If the rods weigh the same and the balance points are the same, we have a set of balanced rods.
The rod center of gravity is used to determine bob weight and also used in torsional balancing
equations such as Holzer.
