carbon fiber push rods and wrist pins
Anyone used/using these ? I bought years ago and never installed. Is there a time limit, for the resin or duty cycles Thanks, flyingwedge.
- loudandproud
Re: carbon fiber push rods and wrist pins
Wait, carbon fiber wrist pins?
I need to see pictures of these...
"Buying parts I dont need, with money that I dont have, to impress people that I dont know".
- nhrastocker
Do not even try to use them.flyingwedge wrote:Anyone used/using these ? I bought years ago and never installed. Is there a time limit, for the resin or duty cycles Thanks, flyingwedge.
They might be strong however, they will not survive the cycle and loads in the valve train.
Many years ago, a friend of mine purchased a set of the push rods after seeing an advertisement in National Dragster.
Installed them in his Comp Eliminator engine and after he warmed up the engine and rev it up, all the push rods frayed and turned into string cheese.
Yes, carbon fiber pushrods were the trick part of the week many years back. The manufacturer went broke very quickly, as they simply didn't live in a race engine environment. Seen anyone running them lately?
Whatever happened to ceramic-aluminum matrix pushrods?
jack vines
jack vines
I think 3M will still build them, for ~$2k per set.
http://solutions.3m.com/3MContentRetrie ... on=current
Think I remember Smokey Yunick trying carbon-fiber pushrods on a SBC dyno run in the '80s. At some critical rpm, they went into resonance and converted back to individual strands. Carbon-fiber wrist pins? That's up there on the bad-idea list with cast-magnesium pistons.
Carbon fiber wrist pins aren't what you think. They are basically a thin walled steel pin with an inner carbon fiber "liner" to bolster the strength. Never really worked link they thought either.
Robert.
Robert.
Yes, They are what you think, no steel but superlight, 17 grams ? I think for sh**ts and gigles, I'll use pins and pushrods in a WTF motor= learning/entertainment factor. Thanks, flyingwedge.
flyingwedge wrote:Yes, They are what you think, no steel but superlight, 17 grams ? I think for sh**ts and gigles, I'll use pins and pushrods in a WTF motor= learning/entertainment factor. Thanks, flyingwedge.
The wrist pins are resin on the OD? Any coating at all?
Trump might screw us
HILLARY WILL SCREW US
i installed carbon fiber pushrods back in the 80s, they broke just cranking over the engine, the steel end at the top where it broke, wedged open the rocker arm, keeping the valve open, driving a titanium valve thru the dome of a handmade piston,which is not a good thing,
>> No resin, just wishfull thinking/lol.axegrinder wrote:flyingwedge wrote:Yes, They are what you think, no steel but superlight, 17 grams ? I think for sh**ts and gigles, I'll use pins and pushrods in a WTF motor= learning/entertainment factor. Thanks, flyingwedge.
I've seen some home made ones. Very thin outer steel shell (like .060') with a solid baked carbon fiber center. They were said to have worked.Robert Kane wrote:Carbon fiber wrist pins aren't what you think. They are basically a thin walled steel pin with an inner carbon fiber "liner" to bolster the strength. Never really worked link they thought either.
I bought a set of carbon fiber push rods for my BBC they weighted in ar 28 grams, they worded good until I wacked the throttle real hard which schreaded them....About three years ago I saw the ceramic aluminum matric ones at the SEMA show, I called to get a price they wanted around $150 each for them, I thought they must be gold plated or something. I guess you better have your lengths correct.
- Dave Koehler
Must Video or it never happened.flyingwedge wrote:Yes, They are what you think, no steel but superlight, 17 grams ? I think for sh**ts and gigles, I'll use pins and pushrods in a WTF motor= learning/entertainment factor. Thanks, flyingwedge.
OK, pay per veiw-engine destruction derby ?Dave Koehler wrote:Must Video or it never happened.flyingwedge wrote:Yes, They are what you think, no steel but superlight, 17 grams ? I think for sh**ts and gigles, I'll use pins and pushrods in a WTF motor= learning/entertainment factor. Thanks, flyingwedge.
