Greetings everyone.
This is a wonderful forum, obviously very many knowledgeable people here.
I was wondering if anyone may have actually measured the intake and exhaust port lengths of a 23 degree small chevy cylinder head?
For a typical smaller 200cc and under street head if it matters.
I'll do mine for sure next time my engine is apart.
Thanks.
small chevy 23 deg head port lengths.
here's some examples
-here's a few that I have seen, flow tested at 25" and all these numbers are at .500" valve lift.
-SBC #186 head -------5.50"---174cc---211cfm---------------1.93avg SIA---262.4 FPS avg port velocity---109.3CFM per sq in
-SBC #993---------------5.19"---182cc---223-------------------2.14------------250----------------------------------104.3
-pontiac #867RI---------5.38"----247cc---274-------------- ---2.80 -----------234.9---------------------------------97.9
-Winston Cup 18deg.--5.44"---251cc---294------------------2.817----------252.5----------------------------------104.4
-Dart 2 cast iron--------5.31"----212cc---248-----------------2.436-----------244.3-----------------------------------101.8
-Dart 2 cast iron--------5.35"----219cc---248-----------------2.50------------238.1-----------------------------------99.2
-Dart 2 cast iron--------5.35"----237cc---260-----------------2.706----------230.6------------------------------------96.1
-351-2V Ford------------4.812"--180cc---248-----------------2.28------------260--------------------------------------108.8
-I use a narrow tape measure, cut off the first ten inches to get rid of the bent end, then I measure along the floor from the port inlet at the gasket face-to the bottom of the seat angle.
-then to do the roof I measure the same way but along both sides of the valve guide, and try to get a pretty good idea, add'm up and average out the length.
-It may not be exactly right but it's easy and repeatable.
