Kaase P-38 cylinder head
Hi, I'm wondering if anyone here has had some experience with Kaase's new P-38 cylinder heads? I've got a SBF I'm considering them for and have heard some big numbers and claims for them. Any one here got any feed back? Thanks
Re: Kaase P-38 cylinder head
Patience, Grasshopper...
While you are patiently waiting for a response you could look up Jon Kasse and see if any of his builds run well I personally think he has a pretty good grasp on things and would not hesitate to use his products if I was doing a Ford engine. He is the man.
I have a friend who had Kasse build a 520 with a single 1050 cfm carb, we went down and picked it up, they had it sitin on the Dyno we we arrived, were hoping for around 840 HP, it made over 850 with ease, met most of the Guys who work there , great bunch, very helpful any time we call, we were back a couple of times since, Beautiful shoplots od ADRL Pro Stock engines, not just Ford, Chev's too. My friend has had great luck with the motor, runs 9.0's @ 146, not a light car, 70 Mustang weighs around 2600. Very low maintenance motor, would buy from Kasse in a minute, you will not find a nicer guy to deal with, not to say his record speaks for it self.
- af2
X 2+++++++++++++++++++++++++++++++++++++++++++++ Those heads are everything the twisted wedge wanted to be.... Hands down900HP wrote:While you are patiently waiting for a response you could look up Jon Kasse and see if any of his builds run well I personally think he has a pretty good grasp on things and would not hesitate to use his products if I was doing a Ford engine. He is the man.
GURU is only a name.
That head is a slightly improved version of the head which Kaase did for Jeg's, (with the Jeg's name on it), a few years ago.Dave C wrote:Hi, I'm wondering if anyone here has had some experience with Kaase's new P-38 cylinder heads? I've got a SBF I'm considering them for and have heard some big numbers and claims for them. Any one here got any feed back? Thanks
From using a couple sets ... they were everything they were supposed to be.
watch the episode of GERZ this weekend. Repeated on Sun. The have a 10 min Seg on these heads with Jon at his shop. Even have dyno runs, Pretty good -Stacy David keeps his pie hole shut and lets the grown-up speak about what They know. Enjoy and Learn. I know Jon, he is from my area-decades ago! Al
Some people are so stupid that they dont even know it! - by a famous Hillbilly
"...Even have dyno runs, Pretty good -Stacy David keeps his pie hole shut and lets the grown-up speak about what They know..."
Worth watching just for that.
OTOH, at least he doesn't "build" rear axles with an impact and a sledge hammer, like some other truck shows do.
Wow! $2500 for a set of his heads they look real nice, but I think I'll go with mor displacement instead
Thanks for all the advice
You get what you pay for with those heads.
But they are more than you need or can use on a small street 302 FT motor. You be much better served with some GT40 ford racing heads, Eddy RPM's or some 185 AFR's
or even a pair of expedition heads from pick a part
but figure out rebuild costs unless you can DIY
If you are going to port yourself start with some cores that have potential
More displacement won't help much with power, (unless "off idle" and "low RPM" torque is your target), when you use marginal cylinder heads ... the heads NEED to match the rest of the package.Dave C wrote:Wow! $2500 for a set of his heads they look real nice, but I think I'll go with mor displacement instead
How far do you want to spin the tires...?
sorry I thought I was posting in the 302 build/ comments thread
but still the same
unless you are running in heads up class evaluate your spending carefully
perhaps someone is moving from TFS or another head and you could pick up the cast offs at a reasonable price for street or brackets (almost)
Walter is correct
a head on different displacements will make about the same amount of top end horsepower, just at a different peak RPM
however "much help with power" will be better all the way up to that point with more cubic inches
The small inch max horsepower engine is more expensive to build and maintain than a big displacement wide power range motor
more top end vs broader power band
Running Bonneville (which also takes a wider torque band that conventional wisdom assumes) or a heads up limited cu in class is one thing
running on the street or consistently running brackets is another
P38s or 347 (or 427 for about the same bucks) not a hard choice for most but if you can budget both...
but still the same
Walter is correct
