best piston ring compressor
MaxFlow
Post by MaxFlow »
What's the best some are using?
Tapered for the bore? Sets? What's the best
thanks.
Joe Stalnaker
WV
governor
Re: best piston ring compressor
Post by governor »
I have a couple of the adjustable taper compressors 4" and 4.125"and have never had any issues even with .043 rings, just need to get them set so the piston just has a little drag w/o the rings on.
Gov
a passion for racing
Cogburn
Post by Cogburn »
I don't know about "best" but a tapered compressor beats a band compressor. Leakdown on the stand drops considerably with the use of a tapered compressor and the bores look better after running the engine.
Amilcar
Post by Amilcar »
Cogburn wrote:I don't know about "best" but a tapered compressor beats a band compressor. Leakdown on the stand drops considerably with the use of a tapered compressor and the bores look better after running the engine.
I can`t understand how it could be other than when the band compressor were used, things got damaged and/or rings ended not in the position they suposed to be.
Cogburn
Post by Cogburn »
Exactly. I think the band compressor does not compress in a perfect circle causing the rings to be deformed somewhat.
Wolfplace
Post by Wolfplace »
The "best ring compressor" ?
I prefer a dedicated bore size tapered one
Next the adjustable tapered ones as long as you don't get stupid with the adjustment
There is nothing what so ever wrong with a "band type"
Either one,, the ratchet or the one with pliers if used properly
The "best one" is the one you are the most comfortable using that doesn't break rings when installing them
Used properly the rings are not going to care what you use & you are not going to deform them with any of the above unless you hang them going in or miss the ring grooves with the tapered ones & keep banging on the piston,,,,,,,,,
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
cpmotors
Post by cpmotors »
I agree with Mike for sure but I have 9 solid/tapered compressors from ARP, B&B, BMP, and Proform and they are well worth the money. If I need an odd size one I buy one close in undersize and bore it to size I need. Still have a band compressor but its a last resort for me.
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
dirtracr5
Post by dirtracr5 »
i agree with mike. i've used a adjustable band compressor which has a built in taper. it is very easy to use and never hangs up even with .043 rings.
MaxFlow
Post by MaxFlow »
Which one are you using dirtracer5?
I have a few dedicated typical sizes that work well but am looking for something for the oddball stuff. I don't want to pay $50 bucks every time I'm messing with a different bore size.
Joe Stalnaker
WV
Dave De
Post by Dave De »
I've been using this set from Gear Wrench. It works well. I purchased a larger ring for up to 4.60" bores. The locking pliers make it easy to use.
https://www.gearwrench.com/products/aut ... ressor-set
Jeff Lee
Post by Jeff Lee »
Using skinny rings, nothing beats tapered, bore specific.
However, I didn’t know tapered band compressors (as mentioned by dirtracer5) existed. Who sells that?
NHRA SS/G
1970 AMC AMX - 390 4-speed
