Can someone please tell me if there is a difference between a set of Ford or Chevy 3/8 x 1.6 roller rockers. I was wondering if the pushrod location is different?
Thanks
Need Help "PLEASE" Ford verses Chevy Roller Rocker
-I have been thru that several times and with the rockers I was trying to use there was obvious differences and I think the length of the trunnion pivot to either end of the rocker is longer on the ford just enough move the pushrod into the Chevy valve cover and the roller tip sits out over center (towards the exhaust manifold side) on the valve tip.
-The same problem is there on the 351C vs BBC 1.75:1 rockers also.
