Dyno result for the risky business Porsche
ptuomov
Re: Dyno result for the risky business Porsche
Post by ptuomov » Sun Apr 19, 2020 11:32 pm
englertracing wrote:
Sun Apr 19, 2020 11:28 pm
ptuomov wrote:
Sun Apr 19, 2020 6:45 pm
Sun Apr 19, 2020 6:23 pm
Did you guys consider gutting that block for a darton mid type installation?
Give that we want to stay with 100mm bore, sleeves of any kind would be a huge cost and unreliability problem. Can be done in a way that lasts but it’s a huge learning curve for this block and even in the end it’ll be way, way more expensive that Nikasil plating.
Um actually the darton mid design was really a solution to open deck block related issues.
Since we don’t have any of those issues at our cylinder pressure levels, aren’t those sleeves then just an expensive solution to a non-problem, for us? We just need to be able to run modern pistons, everything else works as is.
englertracing
Post by englertracing » Mon Apr 20, 2020 9:50 am
Arent you going to keep feeding it more boost
Bwh998
Post by Bwh998 » Mon Apr 20, 2020 10:30 am
Beautiful engine bay, thanks for the picture.
ptuomov
Post by ptuomov » Mon Apr 20, 2020 11:35 am
Nope, because the manual transmissions can’t hold it. That’s why we are going with more rpms not more boost.
ptuomov
Post by ptuomov » Mon Jun 22, 2020 8:20 am
An engine assembly video from a couple weeks ago:
The breakaway torque of the assembled short block ended at 9 lbf-ft.
ptuomov
Post by ptuomov » Mon Jun 22, 2020 2:14 pm
Some assembly photos:
ptuomov
Post by ptuomov » Sun Jun 28, 2020 10:52 am
The long block is in the car:
Fusion Works
Post by Fusion Works » Sun Jun 28, 2020 9:57 pm
Any idea what this engine weighs?
ptuomov
Post by ptuomov » Sun Jun 28, 2020 10:05 pm
Accessories are very heavy so as always it depends. If you include all the accessories and emissions gear, it must be close to 600 lbs. based on shipping weights? The long block isn't nearly as heavy but I don't have a number for you.
ptuomov
Post by ptuomov » Mon Jun 29, 2020 11:07 am
Models Dimensions Tolerances book for:
928 81, 82 Models
928 S 80, 81, 82, 83, 84 Models
Engine weight (dry)
Pg. 14 '81-'82 M28.09/10/15/16 245kg
Pg. 17 '80-'83 M28.11/12/19/20 261kg
Pg. 17 '84 M28.21/22/19/20 261kg
Technical Specifications book for:
928 S Models 85, 86
928 S4 Models 87, 88, 89
Engine weight (dry)
Pp. 16 & 17
85/86
928 S
M28.21/22 261kg
M28.43/44 264kg
86-89
928 S M28.45/46 264kg
928 S4 M28.41/42 264kg
928GT M28.47 264kg
264 kg = 582 lbs. These are with all the accessories, which are very heavy.
The engine external dimensions are not too far from BBC, the bore spacing is 122mm. Deck height isn't too long, but then the four-valve heads make it look like a tall deck block from the external dimensions. It's a small miracle that the engine could be designed to be low enough to fit under the 928 hoodline.
ptuomov
Post by ptuomov » Thu Jul 02, 2020 8:06 pm
Delayed video update:
ptuomov
Post by ptuomov » Sat Jul 04, 2020 10:26 pm
Custom cast exhaust manifolds bolted on, ready to have the turbos to be attached.
dannobee
Post by dannobee » Sun Jul 05, 2020 9:54 am
Those look pretty low in the chassis. Are you running a scavenge pump on the drains?
As far as the gaskets, most manufacturers have moved away from paper and cork gaskets and use either a variation of silicone and a steel shim, or clean up everything and run no gaskets and just some variation of Three Bond/GM Sealer. As you described in the video, it seals very well and requires a few taps with a rubber mallet to separate the two parts.
ptuomov
Post by ptuomov » Sun Jul 05, 2020 10:02 am
Yes, no other way to fit them.
