2 stroke for drag racing cars?
Re: 2 stroke for drag racing cars?
My Geometry teacher in HS always wore a suit and bow-tie. He told me when he was growing up in Indiana in the late 50s and early 60s that his two-stroke Zündapp would climb wet-plaster walls (read riverbanks). He and his friends would also travel around in two Willys Jeeps and pull each other out of the mud.
Don't judge a book by its cover.
Did DKW ever enter competition?
With their 3=6, 2-stroke, 3-banger engine?
You mean as for use in this single seater?
“Ignorance more frequently begets confidence than does knowledge.” -Charles Darwin, The Descent of Man
Sort of off topic, but same thinking....
For context.. A lot of the higher hp 2 strokes released by yamaha and Kawasaki around 1999-2004 were 1200 cc, 155 hp triples. Made peak power at about 7500 rpm.
They had nickel silicone carbide (Nikasil) plated aluminum cylinders. Always wondered why the big 3 weren't using this with aluminum blocks the stuff cant be honed or cut with traditional methods, shows amazing wear resistance and has a host of other benefits. Has anyone used this stuff in an alloy block v6 or v8 with a 7000 rpm max redline?
Bill Chase wrote: ↑Wed Jul 08, 2020 10:10 am Sort of off topic, but same thinking....
The downfall I understand to nikasil is you have do all cylinders over in event of failure. The heat process distorts whole block.
I didn't know what, that's surprising. For example, we do nothing ever to those Porsche blocks in terms of mains, no line boring or anything. They measure exactly the same and the crank spins the same before and after plating. Then again, I don't know anyone who has ever replated a single cylinder of a 928 block, since the Nikasil bores look like new even after "various mishaps".
This is what I’ve been told. My friend who runs a billet big inch chevy was going to go nikasil. However they said if he has a bad failure you usually have to do whole block because of heating process. He set the worlds na record for 1/8 mile couple years ago.
Newer 600cc 4 cylinder 4 stroke sport bikes have 100 hp or more at the rear wheel with full emissions equipment. 1000cc sport bikes are near 200 hp at the wheel...
Full power at 12-13000 rpm with a broad power range for such highly tuned engines...
Rotax 850 turbo is 165 at sealevel and the same at 8000ft. The 872bigbore from trygstad is 185 and his 927 bigbore based off 850 is 210ish. These motors make peak at 8100 rpm. The snowmobile benifits from a cvt belt drive and I’ve never understood why bigger bikes never went this route. Possibly more maintenance over long miles who knows.
https://www.snowtechmagazine.com/ski-do ... tec-turbo/
Yes, 2 strokes can make more power at lower rpms...The sport bikes are N/A except for a supercharged Kawasaki 4 stroke .Bike riders like to shift gears. It takes some skill to work the clutch and throttle just to go 10 mph.You are one with the machine, it can't stand on it's ownSteve.k wrote: ↑Wed Jul 08, 2020 6:00 pm Rotax 850 turbo is 165 at sealevel and the same at 8000ft. The 872bigbore from trygstad is 185 and his 927 bigbore based off 850 is 210ish. These motors make peak at 8100 rpm. The snowmobile benifits from a cvt belt drive and I’ve never understood why bigger bikes never went this route. Possibly more maintenance over long miles who knows.
Lol ..Anyone can get on a sled or cv ATV and go...but it does take skill to go fast..
An experienced bike rider can run into the 10's in the 1/4 on a 600 sport bike. The 1000's run high 9's at 150 mph and top out at just over 200 mph. New bikes are smooth and wind up high with no hesitation.
But each have their attraction...Last time I rode a sled was about 15 years ago...it was damn fast..
OK, let's build a two stroke drag racer.
As a starting point, we could use a currently available snowmobile engine:
B = 82mm
S = 74mm
three cylinder = 1200 cc displacement
rpm = 10000
HP = 270 hp on race gas
Now we can use mapped ignition and direct fuel injection with a turbo:
15 psi boost = 547 hp @ 10000 rpm
20 psi boost = 639 hp @ 10000 rpm
We could use a currently available CVT transmission. Total weight approx 260 lbs.
Now we need a chassis. A used Formula Atlantic; 1200 lbs with full aero downforce package should
do very well for our purpose.
What class would they let us run?
B = 82mm
S = 74mm
rpm = 10000
