Valve/Rocker/Pushrod Geometry
- Wolfplace
Andy,
Very nice
I can see a real advantange although I am not sure it is any more accurate as what I feel we are shooting for is a narrow pattern.
But I can sure see where this would speed up the process.
Sure will beat crap out of removing the rockers, checking, adjusting, installing, rechecking, removing, installing,,
Very nice
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
That rocker arm is from RAS. I built the aluminum shaft supports. This setup is on a BB Mopar.
The tool is a simple idea. Just a block of steel welded to a retainer. Drill the hole for the dial indicator so it is on center with the roller wheel. I added a drilled and tapped hole for a set screw to hold the dial indicator tight. The tool only takes 30 minutes to make but it speeds up the process since it allows you to write down a number for the side scrub. After a few engines you can start to develop a "database" of scrub numbres so you'll be able to compare notes and see how different systems work.
Here is the link to RAS if you're not familiar with them. They are good guys to work with. They have some neat custom stuff and they are great for rebuilding arms.
http://www.rockerarms.com/
Andy F.
AR Engineering
AR Engineering
Andy,
If you built that fixture with a long flat tip attached to the indicator plunger for the roller to work against, would that allow the same fixture to be used on most any stem height/retainer combo?
Also, what is the average amount of side movement you see on a proper setup? Thanks! Nice fixture! MJ
Mack Johnson
'86 Mustang Footbraker
Pump gas 347
6.435 @ 104
Pump gas 347
6.435 @ 104
I'm not sure you need a different tip since most roller wheels are the same diameter.
That 0.080 indicated is a pretty good number for .550 lift. Scrub goes up with lift since the rocker arm arc is fixed. You can map it out on a piece of paper with a arc and a line and calculate the minimum possible scrub.
The only way to reduce scrub from the "perfect" setup is to use longer rocker arms.
Andy F.
AR Engineering
AR Engineering
I read the article in the Circle Track that just showed up. I didn't see anything in there that was new info. Basically just said to set up your rocker arms so they are perpendicular at half lift. The author didn't even mention the possibility of setting up the valvetrain to reduce wasted energy. (the minimize the product of scrub and force method that Chevy engineering recommends).
Andy F.
AR Engineering
AR Engineering
Rocker arm is from Rocker Arm Specialist in Anderson CA. They are a great BB Mopar rocker arm. Investment cast SST with a bronze bushing. The guys at RAS make a lot of cool rocker arms, check them out some time.
www.rockerarms.com
www.rockerarms.com
Andy F.
AR Engineering
AR Engineering
Wow, I have never heard of them. I was looking into the Jesel shaft mount rockers for my Dodge Magnum motor, might have to contact these guys see if they would be interested in building a shaft setup for a Mag motor.andyf wrote:Rocker arm is from Rocker Arm Specialist in Anderson CA. They are a great BB Mopar rocker arm. Investment cast SST with a bronze bushing. The guys at RAS make a lot of cool rocker arms, check them out some time.
www.rockerarms.com
Just a sponge, soaking up info.
There is a guy in SD that built LA shaft adapters for the Magnum heads. He's got all the engineering done but it didn't look like there would be a market so it stalled.
And I was trying to get RHS to offer their 360HPST iron Magnum replacement head with both Magnum roker pads and LA shaft stands and a dual LA/Magnum intake bolt patern but it looks like that is stalled right now too.
Jesse Lackman
http://www.revsearch.com
I posted this some time ago on another similar thread. A (picture) says a thousand words. (Read...CompCams instructions on valve geometry stinks)
Also, how many times has anyone had to cut guide plates (on stud mounted set-up) and re-weld them to get the rockers over the valve tips??
Details, details....
Foxwell Motorsports
Performance Cylinder Head Specialties
http://www.foxwellmotorsports.com
If God is your co-pilot, change seats!
How clever - it refers to one possible method as "correct".
Apparently Jessel, Warren Johnson, etc. aren't "correct", nor are many of the automobile manufacturers, who don't use the 50% lift figure...
Since now we know that there is only one possible answer to the question, I'll just remove all those mistakes I made.
