blow though turbo buick
ALKYBURNER
Post by ALKYBURNER »
anyone had any experience with a blow through turbo on a v 6 buick? have a customer looking at building one for a jeep project, abd just looking for any advice on what to use or how to go about starting the project. thanks
mark gummo
Re: blow though turbo buick
Post by mark gummo »
Did you check over on the turboforums yet? Might find some info there?
turbo5.0 240sx
Ron Clevenger
Post by Ron Clevenger »
Use someone like CSU carbs for your blow thru carb. It also requires a boost referenced fuel regulator. It's pretty straight forward other than those two things.
Blessings............Ron
Creekside Racing Ministry....John 14:6
ProCharger F3-139 blow thru carb gas nonintercooled (6.30 @ 220 mph (done with that)
Currently shaking down Boost referenced MFI alcohol ProCharged system
6.20 @ 240 mph (way more to come)
CamKing
Post by CamKing »
I know aa little about cams for Turbo Buicks.
dave brode
Post by dave brode »
This site was mentioned, mostly a blowthrough site;
http://www.theturboforums.com/
There are a number of exh manifolds that were used on various blowthrough and drawthrough 231s over the years. Those manifolds might be an easy way to go on a custom turbo setup in the jeep chassis.
Note that GM used oddball specific to the car turbochargers on all of their turbo'd buicks and Pontiacs. So, it is more difficult and costly to upgrade the turbochargers. Even the non IC'd efi's buicks use different parts than the later IC'd cars. Turbo'd 231s were used on fwd rivieras too. Iirc, most were carb'd, but there may've been efi'd urbo'd rivieras in the early 80s. I'm not sure how the exh routings compared vs the rwd cars, but iirc, the compressor and turbine housings were different, vs the housings from rwd setups, on at least some fwd setups.
Some info on the factory efi'd cars' setups;
http://www.gnttype.org/techarea/picture ... guide.html
I know you are looking blowthrough, and I might get flamed, but if his power goals are moderate, a drawthrough setup from a '78-'82 carb'd 231 would be quite simple, and water/meth would allow higher boost. I'm not trying to start a drawthough bashing thread. I only mention this in case you didn't know about these setups.
http://beforeblack.net/
Note that the drawthrough 301 transams had a system that looked much like the 231's but they don't share any parts. The 301 turbo was more of a T04, although like all the others, the wheels, housings, etc were not std Garrett stuff. The wheel in the 301 compressor is *somewhere* near a T04B V trim, afaik, the compressor on the 231s is much smaller. Iirc, the 301 and early carb'd 231s used a .8x turbine A/R, the later carb'd and efi'd had a .63 A/R. Iirc, the later carb'd 231's setup's turbine hsg is marked .63.
Some pics of the 301 stuff;
https://images.search.yahoo.com/search/ ... 1+trans+am
Dave
dave brode
p.s. - if you are interested in the old OEM stuff, I have a bunch of printed matter on them, including old articles on hopups on those old drawthroughs.
Dave
Tuner
Post by Tuner »
dave brode wrote:This site was mentioned, mostly a blowthrough site;
I know you are looking blowthrough, and I might get flamed, but if his power goals are moderate, a drawthrough setup from a '78-'82 carb'd 231 would be quite simple, and water/meth would allow higher boost. I'm not trying to start a drawthough bashing thread. I only mention this in case you didn't know about these setups. http://beforeblack.net/
Dave
Word.....Draw though and a QJet is too easy to tune for some people, I guess. #-o
The Radius Kid
Post by The Radius Kid »
The Nazis didn't lose WWII,they just changed uniforms.Now they run the place.
LoganD
Post by LoganD »
I'm baffled as to why anyone would try to do a blow through carb. Get the Vortech carb box and be done with it.
Firechicken
Post by Firechicken »
This is my twin draw thru home fabbed Pontiac built about 15 years ago. Runs pretty well for the junkyard tech available back then...
