Caprimaniac wrote:Thanks for this info, Harry.
I knew the two throttles should be somewhere at 300 CFM. What you lay out there, should be be a great setup as far as I sse it.
I need to look into some of the weber data on the 48 IDA (IDF) for SBF and compare it to the data for The 4.9 Maserati V8. There has been much talk about the webers not supplying enough air on SBF (and FE) setups. (Assuming choke sizes and carb type being comparable.) I suspect some of the rant about too small chokes might be BS....
As I recall, the 48 IDAs when fitted to 5.0 litre (302) Ford V-8s in the 1960s on IR intake generally used 37mm chokes. Those engines were redlined at 7,000 RPMs and more on road race circuits, so there is plenty of airflow available with the larger Webers to support a small block Ford, Caprimaniac.
With a 48mm throttle bore, I wouldn't go larger than 40mm or 42mm chokes, as larger would be difficult to tune, manage fuel metering and maintain drivability...... But they should support a 347 (stroked 302) or even a 408 (stroked 351) small block Ford so long as CSA of the port runners is sized properly.
As the longer stroke small block engines will generally reach redline at lower RPMs due to the increased leverage provided by the longer 'arm' (need to do that in order to keep piston speeds within reasonable limits for sustained high speed running anyway)...... I see no reason why 48 IDA or IDF Webers on IR intake would not be up to the task.
With a 427 FE engine in a Cobra, 42mm chokes will carry the engine to 6,500 RPM shift points on IR intake, but that is pushing the envelope with 48s. There were larger IDA style carbs available from Berg and others which would work on the larger big block stroker engines in the 500 cu. in. displacement range, but they would require correspondingly larger runner CSA in their intake design to allow the larger engines to breathe when fitted with the Berg 58s or 60s.
Hope this helps,
Harry
