15.2:1 according to the emissions test at 3000rpm steady.automotive breath wrote:If we have learned anything from Smokey Yunick and Larry Widmer; the ICE as we know it leaves plenty of room for improvement in the areas of efficiency and performance.Torquemonster wrote:The testing has been focused around fuel consumption reductions - which we are getting good results on.
For giggles we decided to test emissions as well and were pleasantly surprised at the gains there -
so to answer your question again - yes - if the fuel is burned more efficiently - emissions clean up at no cost to power.
Can you tell us what air/fuel ratio you are running?
See that's the interesting thing - we have not even started remapping yet. Yet just letting the stock ECU do it's thing - the car way more than doubled its economy at cruise. Cruising at 100kph now requires breathing on the throttle compared to before
Trust me - if we can get this concept to work on the track - you'll hear about it because we want to see less oil burned and cleaner air....
