Circlotron wrote:SwedCharger-67 wrote: you even see the little bump on the input when the energy is reflected back to the input side.
Shows that it's not easy to choose an ignition system...if you want an efficient one...and trusting the marketing material seems to be of limited value. It puts a heavy load on the tinkerer who has to evaluate all potential purchases on his lab bench!
The duration of the energy dumping out of the primary back to the battery supply is the whole time the purple trace is descending. The attached pic is slightly clearer than the previous one. See the yellow primary voltage trace (100 volts per div) is slightly
above the line for 120uS after the initial poke from the capacitor. This is when and for how long it is pushing juice back into the battery instead of passing through the coil and making spark.
Cars are full of specialised systems e.g. auto trans, diffs, suspension, camshafts, carburettors, exhausts etc etc and ignitions are no different in this respect. Almost anyone can get these things to more or less work, but to really make them sing requires a specialist.
You are still not getting it.
Find a schematic for a CDI ignition, and try to understand how it works.
The DC-DC converter generates 600 V DC from 12 VDC
It CANNOT magically reflect power backwards from the CDI circuitry into the battery.
It just don't work that way!
If I take hot toast and shove it back into the toaster, it DOES NOT reflect energy back to the power company as it cools off.
If I take a torch and heat my brake rotors red hot, and then step on the brakes, it doesn't suck the heat out and make the car move.
If I take a battery charger and hook it up to a fully charged 12V battery, I will NOT get 120V AC out of the wall plug.
If I pump hot CO2 and water vapor into the exhaust pipe of a motor, I will not get Gasoline and Air back out of the Carb.
You follow?
