Throttle's Performance 383 build
900HP
Re: Throttle's Performance 383 build
Post by 900HP »
MELWAY wrote:Could anyone share some info or direction on that trick ass timing cover chopper wheel and pickup ? Cheers James
It's from EFI connection. They have multiple models that are not shown or listed on their website so it's best to call them for the correct application. Mine is for a traditional small block with a 60-2 wheel and no cam sensor provision in the cover (I use a rear cam sensor)
https://www.eficonnection.com/eficonnec ... fault.aspx
(701)893-5010
https://www.facebook.com/pages/Throttle ... 1996281602
900HP
Post by 900HP »
(701)893-5010
MELWAY
Post by MELWAY »
Many thanks 900HP very neat set up
user-612937456
Post by user-612937456 »
I used a 24 tooth reluctor on mine I considered the 58 tooth but an 0399 ecm and harness was convenient for my build. Is the 60 tooth something different? or is it really the 58?
Edit: 0411 computer
900HP
Post by 900HP »
gvx wrote:I used a 24 tooth reluctor on mine I considered the 58 tooth but an 0399 ecm and harness was convenient for my build. Is the 60 tooth something different? or is it really the 58?
Edit: 0411 computer
60-2 = 58
I'm using a Megasquirt MS3-pro ECU and that allows me to use the higher resolution of the 60-2 wheel
(701)893-5010
roc
Post by roc »
Really cool setup, thanks for sharing.
RevTheory
Post by RevTheory »
How's the tunnel ram EFI treating you now that you've got some cold weather time on it?
900HP
Post by 900HP »
RevTheory wrote:How's the tunnel ram EFI treating you now that you've got some cold weather time on it?
Runs flawless............ I haven't done a cold start colder than -5º or so but you can fire it up and drive away if you want to....... no issues. I've put over 3000 miles on it since September............. I drive my car most of the time though for daily driver stuff. I should really get a good video of a cold start one of these days...........
(701)893-5010
FuelieNova
Post by FuelieNova »
Does that sprocket accept a double roller timing chain?
Tom
900HP
Post by 900HP »
FuelieNova wrote:Does that sprocket accept a double roller timing chain?
Tom
Yes........
(701)893-5010
groberts101
Post by groberts101 »
damned Chevy guys get all the trick retrofit timing parts.
I'd love to see a cold start vid of your truck.
77cruiser
Post by 77cruiser »
Talk him into one Sunday morning, it'll be 20 below Saturday night. :wink:
Jim
FuelieNova
Just out of curiosity what timing chain are you using? I have the same setup but with the plastic cover, thinking I might order the billet cover before I install. Not sure I will get to it before spring though. I have a customer in Fargo keeping me out of town to much :)
Tom
rfoll
Post by rfoll »
I have been wondering about fuel economy numbers. The setup looks really cold blooded to me. My conventional sbc street engines pick up 2 mpg in the summer.
Post by MadBill »
Significant F.E. loss is inevitable in cold weather. The warm up to operating temps can take 20 miles, rolling and drivetrain friction is higher and the colder intake air reduces thermal efficiency. 20% loss is not uncommon.
