At the very front of the air filter (closest to hood) there is over an inch of clearance however, I did remove the spacers to give more clearance at the cowl as the air filter sits partially under the cowl...... I may put them back in at some point if I go to a different design filter......or not..... yes, they are 1000 cfm Holley throttle bodies but I'm not happy with them, the throttle blade to bore fit is very poor and even though I've had them apart twice too much air leaks by the blades and to get the truck to idle at 750 rpm I have to pull timing back to 4 degrees........... I'm thinking of switching to twin TPiS mono-blades with a progressive linkage on the rear throttle body, I just don't have the money right now.RevTheory wrote:Hey Mark, couple of questions for ya:
How much room do you reckon you have between the filter and your scoop?
Are those 1,000 cfm throttle bodies with tapered spacers under them?
What compression ratio do you feel is safe to run with that combo, or one similar to it? Texas heat
This engine is a little over 10.5:1 and it's on the edge for 87 octane........... the above chassis dyno testing was on 87 but it's definitely knock limited, there is a little bit more there on better fuel....... The tune up right now is no-knock on 87 and then we have the knock sensor set to pull up to 4º of timing if knock is experienced so there is room for different temps/conditions........... MS3pro can perform knock retard PER CYLINDER which is really really cool.......... it only pulls spark from the cylinder(s) that have spark knock
I don't think Texas heat would be a factor unless your cooling system isn't up to par.......... I run this engine at 180º and as long as your cooling system can keep it there the only difference would be inlet air temp. If you built at 10:1 I'm sure it would be a lot more forgiving as 10.5:1 is pushing it with this combination....... for 87.
