Yep, the FE was supposed to stand for "Ford + Edsel" even though they were also installed in Mercurys. I suppose it should have been called the "FEM", but that's hardly a manly name for an engine family. FT was "Ford Truck". I knew that Ford played games with the displacement call-out when using the same internal dimensions, but until now I didn't know about the U-Haul cast-crank FTsGLHS60 wrote:Jack, going even further off the Super Duty topic there was also a 359 and 389 version of the FT series, same size as the 360/361 and 390-391 but apparently built for rental trucks..PackardV8 wrote:Getting even further off the Super Duty topic, Ford called out their FE-based truck engines as 361" and 391" to differentiate them from the passenger car versions.
Here's some U-haul info from Ford Truck Enthusiast website...
Thanks
Randy
""359FT and 389FT were special fleet engines. U-haul was pushing to reduce costs, so Ford defined a low-cost formula for creating FT engines in special fleet applications sometime around 1973. The result was an engine with a cast iron crankshaft instead of the FT steel crank, and a governor installed (on all?) which reduced the redline about 500RPM below the governed 361FT and 391FT engines to prevent any opportunity for warranty issues resulting from the less robust crankshaft. The lower RPMs resulted in less horsepower output and longer life. U-haul bought them in quantity, and the rest is history.""
For example, Edsel got a 361 FE, which had the same bore 'n' stroke as the Ford pickup-truck 360 FE, and the medium-duty 361 FT and the 359 FT. The Edsel 361 didn't get the extended crank snout of the FT version.
MEL, of course, stood for Mercury, Edsel, Lincoln.
The FE/FT, the MEL, and the Super Duty were all released for model-year 1958. Can you imagine a modern automobile/truck company engineering three-and-a-half new engine families at the same time?
