Plenum box with two inlets and one outlet
ptuomov
Post by ptuomov »
We've got a turbo conversion project with intercoolers in front fenders and the intake manifold fed from behind. This will naturally give raise to a somewhat torturous path for the compressed air pipes. The whole journey culminates at the point where the two pipes need to merge into the single inlet to the intake manifold. What complicates the issue is that the intake manifold is fed thru a (blow-thru) MAF housing that is very close to the hoodline. Therefore, any sort of usual 90-degree Y-merge either doesn't fit or has the risk of producing very inconsistent air flow into the MAF sensor. A further consideration is that the forces acting on any large surface areas will end up being very large.
Here's a solution that John Kuhn who's designing this stuff came up with. Comments appreciated!
Here's the drawing:
Here's where it needs to sit:
Put Search Keywords Here
ptuomov
Re: Plenum box with two inlets and one outlet
Post by ptuomov »
Here's what the fabricated box looks like:
There are multiple vanes/diffusers inside the box to help the air first slow down smoothly and then to make the turn into the MAF housing.
ptuomov
Post by ptuomov »
Side view:
How the pipes will ultimately feed the box:
ptuomov
Post by ptuomov »
The pipe size is stepped up with a very gradual, conical diffuser before the 90-degree turn into the plenum box. We figured out that anything that helps slow down the air speed before the 90-degree turn and the expansion into the plenum box. Because the pipe has to reenter the engine compartment from the fenders, we can't go with the biggest pipe for the entire duration of the path.
I think that two of these are going to flow a lot of air mass at say 25 psi boost, don't you think?
The plenum box is aluminum but these pipes are stainless steel. The space constraints are so extreme at some spots the the better wall thickness is more important than the weight penalty! Mild steel would have been cheaper, but the insides of the boost pipes will look nicer after use with SS. In case someone opens it up and looks! ;-)
midnightbluS10
Post by midnightbluS10 »
Whatever happened with this? Did you guys end up using the box? How did it work? Anything done after that as far as modifying the box or making an entirely new one based on results gathered from this one?
JC -
ptuomov
Post by ptuomov »
midnightbluS10 wrote: Tue Dec 03, 2019 10:44 am Whatever happened with this? Did you guys end up using the box? How did it work? Anything done after that as far as modifying the box or making an entirely new one based on results gathered from this one?
The box worked, but we relocated the MAF (and went to dual MAFs) so now there's a y-pipe there.
BLSTIC
Post by BLSTIC »
I was going to say that a blow through maf sounds like a lot of trouble. But so does blending two maf signals, I don't know of many ECU's thay could handle that and I'd doubt the accuracy of using only one maf in a twin system. The Z32 was twin everything except airflow meter
midnightbluS10
ptuomov wrote: Tue Dec 03, 2019 11:04 am
Thank you! I was curious after coming across this in the 'similar threads' list on another thread.
JC -
ptuomov
Post by ptuomov »
BLSTIC wrote: Tue Dec 03, 2019 3:14 pm I was going to say that a blow through maf sounds like a lot of trouble. But so does blending two maf signals, I don't know of many ECU's thay could handle that and I'd doubt the accuracy of using only one maf in a twin system. The Z32 was twin everything except airflow meter
The box worked great. The MAF also worked great until it went outside the spec range. In terms of air flow, the old system worked well, but MAF out of range isn't ideal in metering fuel and adjusting spark for a turbo car.
The new system with dual blow-thru MAFs works even better, and has a tiny bit lower pressure drop than the earlier box. It makes much more power, but 99% because fuel and spark are now under control.
Neither system had any asymmetry or air flowing in the wrong direction. We were able to test this by running all three MAFs the same time. Air only flew exactly as John intended it.
