Thanks, that makes me feel betterMadBill wrote:You should be fine with the springs; just try not to get the installed height tighter than spec. (Also, 0.657" is the theoretical gross lift. Net with hot lash would be ~ 0.640" and that's assuming the ratio at max lift really is 1.80:1, and without the inevitable rocker deflection.)
Running 0.650" with a well thought-out choice of compatible cam grinder-approved parts with appropriate application-specific lobe profiles (which you can be sure is the case with Mike's stuff) is way less risky than running 0.525" with the typical collection of mismatched and inappropriate bits that the average guy ends up with.
Our 0.700+" lift Jones SR in a 8,000 RPM SBF hasn't even needed the lash adjusted but once (by a couple of thous) in three seasons of road racing, and the springs are still very close to spec.
I found some 3/8 pushrods on the shelf, they are way beefier, and I found my heads were clearanced already for themtenxal wrote:I'd stay with the 5/16" stuff. You may need to split the guide plate to properly center the rocker tip on the valve tip...can make a big difference. They can be tack welded once this is done or left as individual pieces.ctk30 wrote:I have to use guide plates for my roller rockers, one problem, they are for 5/16 size
The pushrods I'm using will have to be .600 longer than stock to use with the shorter solid roller
I'd like to try and run a 3/8" .080 pushrod if it will clear, which may be a decent amount of work to make work
Can you mill these out? Obviously getting them centered correctly will be critical, or when I Mill them and I can correct them if they need to be adjusted for the rocker to sit correctly.
http://www.jegs.com/i/Crane+Cams/271/14 ... HwodpPIOYQ
Steward Components makes .120 wall 5/16" push rods in what ever length you need. Good stuff.
http://stewardperformance.com/pushrods.html
I like the idea of cutting them to get the alignment correct, I had planned on deciding on doing it when It came down to install them
I found comp makes a 3/8 guide plate, I imagine it should work with my crane rockers
http://www.jegs.com/i/COMP-Cams/249/4856-8/10002/-1
