3-4 month hiatus
Started mocking up the engine
cylinder heads over hang the bore a little, I think I'll notch the stop a little on the intake side
I'm degreeing the cam in now, the proform kit for LS engine sucks so I'm going to improvise a little and then return it. After that I'm going to mill the heads as much as I can while still having ample clearance, hoping for .040 - .050, this will be around .060 total as they've already been cut a little. compression should hopefully be over 12:1 and dynamic around 10.75.
Still sorting out the valve springs, might go to the large 1.5" springs and get jesel rockers, trying to stay somewhat cheap for now though as I'm out several thousand dollars on another engine deal currently. My valves are 11/32 not 8mm so that makes it a bit more of a pain, and the crane rockers are limited to 500 lbs open pressure
Found some kooks stainless tri-y headers, they will be here towards the end of the week hopefully. Also bought a super victor
standard air box isn't going to work
