My bench has a 4.3" bore adapter now. Send it along if I can use it I will.Bob Hollinshead wrote:Carnut, I might make a 1/2" thick plexiglass plate to send with this that you can sandwich between the head and the bench, with a 4.310 bore that has a chamfer on the intake side to match the combustion chamber-just to simulate my block. If you think this will work?
Ported Chevy 781 heads
Re: Ported Chevy 781 heads
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Carl, I've seen several good Super Stock class BBC heads that had a small epoxy dam on what we call the bad port SSR to induce the floor bias and swirl .
Don't let those bad ports fool you!!
OH, you ask where I saw them?
How about NHRA tear down for setting records.
Adger Smith
Adger Smith Performance Engines
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
903 794 7223 shop
903 824 4924 cell
Yes sir, amazing what some epoxy can do. Kinda funny the "bad" port design...hmmmm anyone look at the LS portAdger Smith wrote:Carl, I've seen several good Super Stock class BBC heads that had a small epoxy dam on what we call the bad port SSR to induce the floor bias and swirl .
-Carl
-Carl
Look at the splayed valve V-6 I run. Humm! Same bad ports (all 6 of them)!
Adger Smith
903 794 7223 shop
903 824 4924 cell
903 794 7223 shop
903 824 4924 cell
Ya, stupid engineers making bad parts I thought I was wrong once but I was mistaken.
I hope the typing comes off as facetious
Sometimes typing on the interweb is like wetting your pants while wearing a dark suit, you get a warm feeling all over and nobody notices.
Code: Select all
fa·ce·tious
fəˈsēSHəs/
adjective
adjective: facetious
treating serious issues with deliberately inappropriate humor; flippant.
-Carl
-Carl
Where is the "Like button"??
Adger Smith
903 794 7223 shop
903 824 4924 cell
903 794 7223 shop
903 824 4924 cell
In the 90' Chevy built a symmetrical port head. All bad ports. Funny.In-Tech wrote:Yes sir, amazing what some epoxy can do. Kinda funny the "bad" port design...hmmmm anyone look at the LS portAdger Smith wrote:Carl, I've seen several good Super Stock class BBC heads that had a small epoxy dam on what we call the bad port SSR to induce the floor bias and swirl .
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
I'd like to see some pics of that epoxy dam, know of any? I would guess the dam would favor the cylinder side of the port to promote flow on the cylinder wall side?Adger Smith wrote:Carl, I've seen several good Super Stock class BBC heads that had a small epoxy dam on what we call the bad port SSR to induce the floor bias and swirl .
Pro question poster.
Are you kidding I would have got my butt kicked by the owner if I took out my phone and took a picture...
Adger Smith
903 794 7223 shop
903 824 4924 cell
903 794 7223 shop
903 824 4924 cell
On youtube somewhere is an old 396 Corvair convertable from Long Island. These 781's came off that 396. Cut for 2.25/1.88 valves. I had no 2.25 valves in stock so I tested with 2.3 valve. Valve job is very thin with nearly no 60 degree cut.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
I think these have less metal removed than first set.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
